Question about Suncourt Room-to-Room Fan - Circulate Cold or Warm Air from Room to
My heater blows cold air all the time - Suncourt Room-to-Room Fan - Circulate Cold or Warm Air from Room to
My heater blows cold air 85% of time
You got a bad heater door module most likely or the door itself may have issue.
Jan 08, 2015 | Cars & Trucks
Car heater blowing hot air all time
THE HEATER CONTROL CABLE, VALVE, OR SOLENOID IS STUCK OPEN......LETTING COOLANT INTO HEATER CORE AT ALL TIMES
FIND BAD COMPONENT-REPAIR
Jul 21, 2013 | Peugeot 306 Cars & Trucks
Air conditioner charged won't blow cold air, heater core will not let cold air enter into the vehicle. If I close off the heater it will blow cold air. Heat blows all the time even in off postions
It sounds like you either have bad controls or stuck dampers in your vents. The stuck dampers are usually caused by plant debris getting in to the air system.
Jun 07, 2010 | 1998 Chevrolet Blazer
2000 satin sl1 heater blows cold air, had the
my 2000 saturn sl blows cold air with the heater on. I changed the thermostat,and checked out my heater core.Still blows cold air.
Jan 17, 2010 | 2000 Saturn SL
Heater not working it is blowing cold air at all times is there a
Heater blowing cold air until I get on the interstate, then it works; however, when I stop at lights it starts blowing cold air again. The temperature gauge will be in the middle but the car will still be cold until the car starts moving.
Nov 14, 2009 | 2002 Jaguar X-Type
Heater blowing cold air with coolant, fine with plain water
it sounds like the heater core is clogged bad if u know someone with a air compressor put a air nossel on it that you pull the trigger to blos air in to the heater core after you take the lines off i had to do this before on a jeep cherokee it did the job
Jan 11, 2009 | 1994 Toyota Previa
Ford Expedition 2002 Front Heater blows cold air below 45 MPH
impeller is made of plastic on teh water pump and its slipping and spinning on the shaft renew before weather warms up as engine will overheat
Dec 31, 2008 | 2002 Ford Expedition
1997 audi A4 heater blowing cold air
You will have to change the heater core. 9 out of 10 times, when the heater is not heating the air, it is a bad heater core.
Nov 12, 2008 | 1998 Audi A4
Suncourt Room-to-Room Fan - Circulate Cold or Warm Air from Room to Logo
11 people viewed this question
Top Suncourt Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Suncourt Heating and Cooling Expert? Answer questions, earn points and help others
