Question about Hoover Washing Machines
HOOVER VISION HD DRUM PADDLE HAS COME OFF HOW DO I REFIX
HOW DO I GET ACCESS TO THE INNER DRUM
SOURCE: error code 9 on hoover vision hd
Dear Carol. I'm writting to you because I encounter the same problem with the same washmachine (Hoover Vision HD 9kg): fill/empty ok but the drum won't turn = error 09!
My guarantee is out of date only from 3 months and Hoover Switzerland won't help me (I have to pay for the reparation more than the machine price!!!)
I've read on another web forum that the problem could be due to an electrical component (BTB12-600BW), but before to try to change it by myself, could you please tell me how did you resolve your problem???
Please, answer me at "maisoui_cyber@hotmail.com"
Thank you
Johan
Posted on Apr 28, 2010
  • 3 Answers
SOURCE: hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
Posted on May 13, 2010
SOURCE: hoover vision HD 1400 AAA 8kg washing machine -
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Posted on Jul 18, 2010
SOURCE: After a power cut my washer wont work the door
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Posted on Apr 29, 2011
  • 6277 Answers
SOURCE: What does E14 mean on Hoover vision hd mean.
Sorry but the only references to 'E14' I have on my general Hoover list is 'heater/NTC'
'NTC' stands for 'Negative Temperature Co-efficient' or water temperature thermostat to you and me!
One way of hopefully getting around the problem is first to ensure the washer is empty then pour the contents of a boiling kettle into it. That can sometimes kick the device into correct action.
Another thing to carry out is heater clean- in case it is caked in calcium.
I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour a kettle of hot water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever, in fact some good! You could also consider repeating the action.
These are worth a try anyway before having to call in the repair man ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 14, 2011
Hoover vision hd
the bearing are gone
Jan 18, 2014 | Washing Machines
Hoover vision hd 8kg door security button flashing
i now have same problem- did you get a solution?
Feb 17, 2012 | Hoover Washing Machines
There sems to be something scraping and catching between the outer and inner drum,how do i access this area to check the problem out?aquarius wml520
remove agitator on centre shaft there is a nut that has to bee removed if spin tub wobbles that may be the problem
Jun 16, 2011 | Washing Machines
Hi i was wondering if you help.my hoover hd vision
May 12, 2010 | Hoover H160E Front Load Washer
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
Feb 01, 2010 | Washing Machines
Error code 9 on hoover vision hd
Thank you
Johan
Jan 10, 2010 | Washing Machines
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
