Question about Canon Office Equipment & Supplies
Error 202 scanner - Canon Office Equipment & Supplies
How do i get i n h off of display of my radio shack htx 202
HTX-202 (190-1120) Error Codes Faxback Doc. # 15722 Your transceiver has two error code displays. Refer to the following for an explanation of each error code. Er1: INTERNAL RAM ERROR Er1 indicates the transceiver has detected an error in its battery-backed up operation memory. This is the most commonly caused by a low lithium backup battery, but can also be caused by static discharge, or a physical shock. To clear the error-- 1. Turn off the unit. 2. Press FUNCTION and CLR (the D key). 3. While holding these keys, turn unit on. This will reset unit and clear memories. If the transceiver frequently displays the error, have the battery replaced by an authorized Radio Shack service center. ER2:PLL UNLOCK ERROR Er2 indicates the transceiver's PPL section has unlocked. Have the transceiver repaired by an authorized Radio Shack service center. (/ir-07/31/95)
Nov 01, 2014 | Radio Communications
Canon imageclass mf4412 turn on power supply E-202-0002 error solusation
for canon mfp4412 e202-002 error
turn off printer
open scanner
check scanner is working or making noise
if it making noise check scanner flat cable on formator boad side or replace cable
Dec 03, 2012 | Office Equipment & Supplies
202 0001 error code
You have a problem with the scanner unit or the scanner lamp. Not sure which one, you did not give a model number
Sep 03, 2012 | Canon Office Equipment & Supplies
Canon MP280 Scanner error code 5, 202, 54
I think that you haven't downloaded a driver.You'd better access the Internet to download one.(I just solve it in China this way.)
Dec 30, 2011 | Canon MP280 All-In-One InkJet Printer
Solutoin error 202
That is The scanner does notreturn to the home position for vertical scanning within a specific time. This code must not be indicated on thecontrol panel. It should be checked with Service Mode.
Jul 21, 2011 | Canon imageRUNNER 8500 Copier
202 Paper Jam om Lexmark c510
1. Make sure the printer is on.
2. Raise the scanner unit.
3. Remove both print cartridges.
4. Make sure the cartridge carrier lids are closed.
5. Close the scanner unit.
6. Press to turn the printer off.
7. Disconnect the power cord from the wall outlet.
8. Plug the power cord back into the wall outlet.
Jun 09, 2017 | Lexmark C510 Laser Printer
14 people viewed this question
old marine
old marine
