Question about Electrical Supplies
Hpm switch wiring diagram - Electrical Supplies
2 Suggested Answers
emissionwiz
  • 76682 Answers
SOURCE: wiring diagram on HPM power point 2ws 38
Fixya has no wiring diagrams other than those found with a search engine. Sorry.
Posted on Feb 10, 2012
How do I set a 24 hour timer D809/1
HPM 24 hour timer instructions: rotate dial clockwise until current time lines up with pointer located on inner dial. There are segments located around edge of dial. Pull up these segments to set on-off times. Turn Load switch ON. Plug Load into timer. Plug timer into receptacle. Manually rotate dial clockwise and observe Load turning ON-OFF. This will show if timer is ON or OFF when segments are pulled up.
I think the D809/1 has 15 minute intervals. The only manual on the HPM site for a 24 hour timer close to this is:
https://hpm.com.au/app/document/asset/23/16/6/d8180d-hpm-24hr-outdoor-timer-instruction-sheet.pdf
Sold at Bunnings in Australia, you might find a manual with one! Alternatively, here is another place they are sold and given they are inexpensive, it might be worth it to just get the instructions. Amazingly, if you try to search for a manual for this, you can not find it. You just get comments like the techs were not help, the manual was in Chinese, and after translation, were not even understood by the techs. Heaven knows what the truth is. The HPM manual above is clearly in English. Note the device manual above likely is set for half hour intervals. Good luck.
http://www.radioparts.com.au/ProductDisplay.aspx?popup=1&Category=SXKK1045&Product=49161200&ProdDesc=D809%2F1+24+HOUR+ANALOGUE+TIMER+HPM
Aug 11, 2017 | Hardware & Accessories
Hpm wiring diagram
http://waterheatertimer.org/How-to-wire-switches.html
Neutral is required to complete circuit in 120V 2-wire circuits
Gene
Aug 15, 2014 | Electrical Supplies
Wiring diagram on HPM power point 2ws 38
Feb 10, 2012 | Cars & Trucks
Hpm 24 hr manual timer , i dont know how to get it working
HPM 24 hour timer has segments located around dial.
http://waterheatertimer.org/Woods-timers-and-manuals.html#HPM-dial
http://waterheatertimer.org/images/hpm-24hr-timer-500.jpg
Segments appear to move up or down.
Other similar timers: Segments down = Load ON; Segments up = Load OFF
Press several segments down.
Plug timer into wall.
Plug 240Volt load into timer.
Manually rotate timer dial clockwise to see if segments down turn load on or off.
There is also a 2-position slide-switch located on top of timer.
Move slide switch to each position to see which is need for timer to turn load on-off.
After positions are defined, push segments down or leave segments up for times you want load to turn on.
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Timer dial rotates as time passes, and segments move a plastic lever that turns load on and off
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 20, 2011 | Hardware & Accessories
HPM D817/2 electronic timer 7 face buttons, Manual required. Thanks
1) I have located a similar timer, with similar buttons.
Tork 451D with manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
The buttons are in different order, and Tork is 120Volt timer, not 240Volt like HPM.
This information may help if you have HPM timer and can experiment.
I doubt this information will help if you are simply looking for a clear cut 1:1 manual to sell on-line.
2) The HPM timer does not sell in US, but the timer is inexpensive and you can purchase the timer for $27 and scan manual into pdf format.
3) HPM also has a contact us page, but I don't know if they will send manual of if link is good:
http://www.hpm.com.au/Products.aspx?pid=18#Timers/Timers/7-Day-Timers
Dec 26, 2010 | Hardware & Accessories
Need to replace the HPM dimmer switch with a normal switch
This is not a difficult job. First of all go out to a home depot or other hardware store and purchase one three way switch. They come in white, cream, and brown.
Back home, kill the power to the lights you are working on. Then open up the dimmer switch, the other switch doesnt need to be changed. Now, simply draw a diagram of where each wire color is now connected and remove the old dimmer. Reconnect the wires. Remember that the white wire goes on the dull color screw and the other two go on the brass screws. Turn the power back on.
If you do all this and the switch only works correctly part of the time just reverse the two wires on the bright brass screws. Please mark this answer as a fixya!
Mar 09, 2009 | Electrical Supplies
Sony HPM-70 not working with music feature on phone
I got a "failed" when I tried to listen to my playlist, on the first song. I switched to a different song lower down the list, and then it worked. Not sure what made the difference.
Feb 06, 2009 | Sony HPM-70 Headset
SONY ERICSSON HPM-85
i have a w595 and hpm 85, its connection is loose when i connect it if the port moves the handsfree logo dissapears
Jun 17, 2008 | Sony Ericsson HPM-85 Consumer Headphones
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
