Need to replace power board in whirlpool wfs1073dd front load washer. Apparently a common problem occurring just after warranty expires!!! How do I replace the board?
Need to know how to access the power board to replace with new one on order. Thanks
aborcass
  • 2651 Answers
SOURCE: washer won't drain Whirlpool Duet GHW9150P Front Load Washer
you can gain acess to the pump cleanout by removing 3 torx 15 screws from along bottom of front panel. justbehind the panel youl find the "bttoun trap. unscrew it and chances are youll find baby socks, bra underwires, etc... )somethings blocking the pump from orkin proerly, be warned scoop water out first, and tip unit back if possible. when oyu unscrew the pump clean out all water above will be coming out
Posted on Mar 12, 2008
aborcass
  • 2651 Answers
SOURCE: Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
Posted on Dec 03, 2008
  • 3 Answers
SOURCE: kenmore elite oasis washer
Today (4/3/09) I got a letter from Sears. They will replace the electronic control board (you know, the F-51 business) for FREE, in warranty or not. Serial #s for the Bad Board begin: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083. The voices of all of us have finally been heard! There is a class action attorney firm in San Francisco looking into a legal remedy.
Posted on Apr 04, 2009
  • 41 Answers
SOURCE: Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Posted on May 14, 2009
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Door won't unlock whirlpool wFs1073dd front loader
If it has water in the the machine, it has a safety feature that will not allow the door to unlock. There is a manual release but you have to take the bottom kick plate off. Unplug the washer. Then reach up on the right side of the washer and you will feel a plastic lever about the size and shape of a nickel pull down on this lever to release the door. If it full of water i would clean the pump first to get rid of the water. you can clean the pump by taking off the kick plate and you will see a pump with a lid with a handle on it. you can unscrew this and it will have a trap attached to the back of the lid. pull the trap out and clean any debris out then screw it back in. make sure to have buckets and towels handy once you unscrew the lid any water in the machine will fly out at you. the easiest way to avoid this is to clamp the hoses that go to the pump.
Aug 24, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer Model# LHW0050PQ3 Which board do I need?
Sounds like possibly a bad control board.
Try to unplug your washer for 5 minutes then plug it in and run a load and see if it still does it.If not, you will need to replace the main control board.
May 11, 2012 | Whirlpool LHW0050PQ Front Load Washer
HE2 washer motor control board caught on fire. is it worth fixing? I can replace the board myself
Good evening to you. I am sorry for not attending to your problem before now.
I am certain that you have solved it by now, if not give me an other try.
For a long while now my different diagnosis and self have had differences of opinions so inactive Ihave been.
Hope you have solved your challange
Kolbrun
Nov 18, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool Washer #WFW8300SW01 will not operate.
There's a couple of reasons for the F-01, most common is a bad relay on the main control board. (CCU)
This washer will also flash that code if:
1: Either the back or front access panels are removed while operating, there are ground safety switches that are held closed by the panels.
2: If the power supply outlet is supplying much less than 120V (usually would need to be 112V or less to cause it)
3: If the polarity is incorrect (hot and neutral reversed) at the outlet
4: If there is an open ground at the outlet.
The easiest way to check 3&4 is with a simple plug in outlet tester. I have seen all of these problems throw an F-01, but I would still say 9 out of 10 times you have no option but replacing the CCU. Make sure to double check your manual about the warranty info, as some electronic controls are often covered beyond the 1yr standard warranty. If you're going to replace it yourself, it is accessed by removing the top panel, and is located towards the front, right side of the cabinet, and has a zillion wire harnesses plugged into it. When replacing the board, note that there may be some harness connections available on the board that are not used, mark them as such. Hope this helps.
Nov 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Apr 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet steam washer has no power!
call whirlpool, sounds as if you have a faulty electronic control board( power supply board) warranty issue, non need for you to get involved with the repairing of this
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET HT FRONT LOADING WASHER
This is a strange problem. I work on these all day, and never have a problem getting these boards. Might want to try and calling local part houses for this part.
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
