Fix for thorn 42thlchd1 panel starting up then shutting down
The panel starts fines then turns off. Sound is fine TV is a Thorn 42thlchd1.
SOURCE: Philips 42 in. Plasma shut down
Thank god we purchases the ADVANCED extended warrenty. This tv has been nothing but problems.
Fuzzy picture, picture shutting off after 20 sec coming back on and now blog of colors shut off never to come on again. 7 blinking red lights on the front. Waiting for the repair man again.......
Posted on Apr 13, 2008
  • 3 Answers
SOURCE: LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Posted on Jul 30, 2008
SOURCE: POLAROID FLAT PANEL TV PICTURES JUST GOES!!!!!!!!!
Its under warranty
Posted on Jan 24, 2009
  • 187 Answers
SOURCE: 37" Sony Plasma won't remain on
Your mainboard is damaged, replace it and that will solve your issue.
Posted on Jun 06, 2009
budmrtn
  • 11361 Answers
SOURCE: tv turns black after about
You may have power supply problem due to bad component or bad solder joints that expanded when warm up, or problem in the backlights inverter circuits, or bad T-CON board.
Try this when the screen black out.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on May 01, 2011
Hi I have a THORN hd smart tv 55' turns on but then just black screen sound is fine can change the channel but can't see a thing tried unplugging it holding power button down for 60 sec
I have a 55inch thorn TV not a smart TV Tho n it keeps randomly turning off day and night n once it flicked from hdmi channel to normal TV channel, no set some or anything I'm worried a fault or boogidy, it's bout 5 or 6 years old n only been doing it the last week ??
Mar 31, 2017 | Televison & Video
How do i watch a 3d movie on my 55"thorn tv?
the tv automaticly determines if it should go to 3D mode as long as the DVD player or say like PS3 or PS4 is connected to HDMI (yes those two game consoles will support HD Blueray 3D and DVD 3D movies) if the TV isnt displaying 3D look into the video settings of your TV to enable that ability also your TV will come with 3D glasses if the TV supports 3D
Mar 02, 2017 | Televison & Video
Does a philips srp3013 universal remote work on thorn 55thl3ds1 tv if so wots the code please
You can use code search to find something that can handle some or all functions of your Thorn TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Nov 03, 2016 | Philips Televison & Video
Why is it that After an hour or more When I turn on my thorn Tele I get sound but no picture,now I get nothing on the screen at all
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 19, 2016 | Televison & Video
How do i record on thorn smart tv
Not a normal function of any TV
Sep 12, 2015 | Televison & Video
My thorn LCD TV when on the smart tv input setting doesn't work all it says is android it's the fifty five inch three D version
Fixed mate, had the same problem with my thron TV, iv posted the solution on your other post.
Aug 06, 2014 | Televison & Video
2004 Lincoln LS won't accelerate at 60mph, dies
Why would a dealer not be able to find the issue?
Start by checking codes.
If you have to, drive with a scanner,not a code reader on it,to capture data.
If it only has issues when turning the steering wheel and is speed related with the turning, you have a place to start.
I assume the dealer did all that.
I have a 2004 V8,so let me know, what help you need.
Mar 18, 2010 | 2004 Lincoln LS
Changing boiler programmer
take digital pictures - label all wires and reconnect - you do not need manual.
Oct 27, 2008 | Water Heaters
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
