Question about HEWLETT-PACKARD Color LaserJet CP5225 Printer
Cp5225dn error 59.0240
Error 59.0240
  • 731 Answers
This error is indicative of a motor not working properly.
Reseat all cartridges and drums and remove and reseat the belt.
I've seen the belt cause all kinds of issues.
Posted on Apr 01, 2016
HP CP5225 giving error message "Re-install image transfer belt" belt is brand new, fixing properly, repeatedly same message appears.
Did you have the printer powered off before you installed the belt? If not the fuse has blown and the message will be on until you replace the belt again.
Feb 13, 2017 | HEWLETT-PACKARD CP5225dn Laser Printer
GOT ERROR CODE 59.FO, HOW TO FIX THIS PROBLEM
This indicates an issue with either the transfer belt or the sensors that monitor it. Does the transfer belt turn freely if you turn it by hand using the gear on the side? Do not touch the belt surface.
Sep 08, 2016 | HP Color LaserJet Professional CP5225dn...
My HP color Laserjet CP5225DN shows message: "Used Cartridge". How can I fix this?
It is telling you that a used cartridge is installed so that you know that the toner tracking system cannot guarantee exact remaining toner indications. The used cartridge message is not generated by a non-HP cartridge, Non HP cartridge will generate a different error.
Jul 16, 2015 | HP Color LaserJet Professional CP5225dn -...
HP Printer, CP5225, Error message, Right door open,
Recommended action
  1. Close the door.
  2. Use the right-door switch (SP15) test in the manual sensor test to verify that the switch is properly functioning. If the switch fails the test, replace the switch.
  3. Check the sensor flag on the right door assembly. If it is damaged, replace the door assembly.
  4. If the product has been recently serviced:
    1. Check the connector (J708) on the 24V interlock switch and the connector (J181) on the DC controller PCA.
    2. Reseat the formater board and retest.
    3. Reseat the ICB and retest.
Nov 30, 2014 | HEWLETT-PACKARD CP5225dn Laser Printer
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
Reset menu english CP5225dn
You can change it in the Display Settings Menu. Print a menu map under administration/information to navigate your way
Feb 14, 2014 | HEWLETT-PACKARD Color LaserJet CP5225...
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
HP CP5225 printing from iPad problem
HP has a list of solutions for print quality problems. Have you tried all the solutions suggested here?
Troubleshoot problem for HP Color LaserJet Professional CP5225 Printer...
There were also a couple Mac specific solutions available (links look the same but are different). Both solutions are about prints being different than expected.
I am an HP employee.
Apr 20, 2013 | HEWLETT-PACKARD CP5225dn Laser Printer
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
HEWLETT-PACKARD Color LaserJet CP5225 Printer Logo
426 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
