Question about Plumbing
Weekend fixture sportstake - Plumbing
Midweek sportstake predictions for 22 nov 2017
user flagged for non repair question
Nov 22, 2017 | Computers & Internet
Tip
Hello. Here is a great weekend project that anyone can succeed with. Under...
Hello. Here is a great weekend project that anyone can succeed with. Under cabinet lighting is such an enhancement to the function and cheerfulness of your kitchen. My most recent experience with this was very successful. The kitchen really needed the extra light and, the home owner let me choose the fixtures. I selected Utilitech line Voltage Xenon Lights from Lowes. These units come in three lengths, 12", 18" and 24". They can operate alone or in groups, they use 110 volts and no transformers, and they have a high/lo/off dimmer switch built in. Finally, they can be installed using the enclosed plug-in cords, or direct wired, and you can link up to 600 watts. A twelve inch bar is 40 watts.
All of that said, all you need to proceed is about 45 minutes per cabinet, and the following tools: electric drill and a set of wood flat drill bits, flat head screwdriver, philips screwdriver, wire cutters, wire strippers, pliers, safety glasses and a small mirror. The mirror will assist you in tightening the screws as you install the fixtures under the cabinets. Turn off the power at the breaker for the circuit you are working on [unless of course you are going to use the plug in cords included in the box instead of direct wiring].
VERY USEFUL TIP: probably the most difficult part of this task could be mounting each of the light bars uniformly under the cabinets. Recognizing this, I made a template for each of the three lengths of fixture so that I knew exactly where to predrill and start the two mounting screws required per fixture. These templates were made from still cardboard, cut with a razor blade knife, although you could have used 1/4 inch plywood just as well.
on Dec 10, 2009 | Baby Care
Tip
How to upgrade the under cabinet lighting in your kitchen.
on Dec 07, 2009 | Electrical Supplies
Sportstake weekend tips
You want glues for fixtures. It depends on the materials you want to affix. Sk ce you question is about shoes, the surface prep is almost more important than the glue. Use of the right primer can make or break the glue job
Jun 06, 2014 | Clothing Accessories
Mod232le ssfbd32r
You need to clean out the pilot fixture or replace it.
Jan 27, 2014 | Heating & Cooling
Just installed a Moen shower fixture, & the knob for the shower head doesn't send water to the shower head-- I don't get it!
I just installed one this weekend. Make sure that the cartridge has the embossed "HC" at the top (for Hot on left, Cold on right) when you slide it back in. Also, before putting the handle on turn the cartridge shaft so that the completely flat part is toward the top and the side with the small notch at the end is toward the bottom.
Jul 26, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Plumbing Logo
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
