Question about Canon PIXMA MX310 All-In-One Printer
Canon MG2500 jammed envelope - Canon PIXMA MX310 All-In-One Printer
Can I access my printer through my computer with PIXMA MG2500 series
Sue, Yes, you connect your Cannon MG2500 with a USB cable, normally this cable would have been supplied with the printer. Check the attached link,instruction and guide, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How do connect my laptop to my Canon PIXMA MG2500 without using cable Just...
Aug 18, 2016 | Office Equipment & Supplies
How to load envelopes in a canon mg3250 printer
Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif You can only print on envelopes with the computer.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive Prepare envelopes.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Press down on all four corners and edges of the envelopes to flatten them.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the corner of the envelope flap is folded, flatten it.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm). Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides. (5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Be sure to open the paper output tray when printing. If not open, the machine cannot start printing. After loading envelopes
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image003.gif Select the size and type of the loaded envelopes on the print settings screen of the printer driver. You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
Nov 13, 2014 | Canon PIXMA MG3250 All-in-One Inkjet...
How do I print envelopes?
In the lower tray, remove the paper.
Adjust the side paper holders to the width of the envelope.
Envelope should be face side or print side facing down.
Usually have to load one at a time to avoid jam.
When finished, reverse the process to normal paper.
Sep 15, 2014 | Canon Pixma MX922
Drivers and software for canon pixma MG2500 printer
Hi mate,
This is the direct link to download the drivers and software for Canon Pixma MG2500 for almost all versions of Windows :
http://support-asia.canon-asia.com/contents/ASIA/EN/0100536801.html
Hope this helps. If you like it, Please leave me a rating.
Cheers.
Nov 03, 2013 | MSI Intelligent Management Bus Driver 1.5
I have an envelope stuck inside my canon mp620 printer somewhere. How do i get it out?
There are three areas for paper jam clearing.
1. Under the scanner cover
2. At the rear of the printer is a small door with rollers at the top. it comes away from the printer from the left. There are some small pins to hold it in on the right. Swing it out to remove the door.
3. The cassette tray. Remove the tray to expose jammed paper or envelopes.
Here is the diagram for the rear door.
Do not touch any components inside the printer.
May 21, 2010 | Canon PIXMA MP620 All-In-One InkJet...
How come i can't print on 4 3/4x6 1/2 envelopes? The envelopes keep getting jammed in the machine.
try the bypass.... if unable to print via bypass then clean rubber bypass feed rollers with alcohol... next step... see if it jams at the finisher... if so set the machine to exit from an internal tray... if it has one...
Dec 12, 2009 | Canon imageRUNNER C3220 Color Copier
Not printing envelopes and printer locks up
Use a small flash light and check for any debris blocking the roller from the tray...
Sep 24, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
35 people viewed this question
old marine
old marine
