Question about Pride Celebrity Xl 4 Wheel Scooter
I have an old scooter called leader. it has a puncture with the freewheel lock side how do i take the wheel off.
4 Suggested Answers
gewiz
  • 1263 Answers
SOURCE: The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
Posted on Jul 25, 2009
SOURCE: I have a Pride Gogo 3 wheel scooter. Suddenly I
the lever at the back may be slack and missing the turn-point. Try moving up and down a few times, very gently, this may get the correct position,.
Posted on Sep 14, 2009
  • 16 Answers
SOURCE: pride celebrity 4 wheel wont turn on
Hi
Please Check that your Freewheel Lever is Fully in Position as if is Slightly out of Position it will Not Work,
Gerry.
Posted on Aug 01, 2010
Mother's scooter keeps dying
How old is the battery they don't last forever and they are not cheap
Sep 28, 2015 | Pride Go-Go Elite Traveller 4-Wheel Travel...
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Aug 25, 2014 | Health & Beauty
Celebrity x mobility scooter . error code 5
The freewheel lever is in the neutral position (which allows you to move the scooter around by pushing it. Turn the key switch off then move the lever to the drive position , turn it back on and it should run fine. The freewheel lever is sticking up through the plastic cowl. It is located under the seat on the right hand side near the rear of the sccooter
May 27, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
The red light flashes 5 times scooter will not move
I would look at the freewheel lever. Disengage and then engage the freewheel and see if this corrects the problem. If not, you may have a bad freewheel switch.
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
My scooter wont charge
Check to make sure the scooter isn't in free wheel. Make sure the scooter's drive is fully engaged. My scooter gets wet and that wetness messes with that mechanism I have to lub it about every two months or so. There is a switch associated with the freewheel lever that disconnects power [hot side] from the motor when the lever is in the freewheel position. On my scooter this switch gets stuck open or the lever will be stiff and will allow the switch to close. WD40 helps.
May 17, 2012 | Health & Beauty
In Drive position the wheels are locked and in neutral the wheels remain locked and will not spin or free wheel. In drive with the battery in the unit just clicks but does not move, everything works such...
I would suspect that the brake is not releasing causing your problem. When you place the handle in freewheel and you can't push the scooter easily then the brake pad is stuck on the motor housing. If you are able remove the seat and back cover remove the drive wheel on the side of the scooter nearest the freewheel lever usually the right side. you should be able to see the brake attached to the end of the motor with 3 or 4 hex head screws. take the brake off the end of the motor and carefully leave the wiring attached ( don't break or remove the wires going to the brake or the scooter will not run at all) remove the brake and place or tie it up where it won't fall or drag. Put the drive wheel back on and turn the scooter on and see if it will now move. If it moves like it should you will have to replace the brake. You can drive the scooter like this but remember you do not have brakes so the scooter can roll backwards or forward when not on and especially on ramps Hope this helps
Apr 23, 2011 | Drive Medical Drive Falcon 3 Wheel Compact...
How to remove rear wheel to have puncture repaired please.
  1. Turn fuel tap off.
  2. Remove both side panels.
  3. Lay scooter on engine side ( on some kind of blanket or mat to protect the bodywork. don't forget handlebars and front mudguard.)
  4. Remove the 5 nuts holding the wheel to the hub with a 13mm socket. (make sure you remove the hub nuts and NOT the 5 which hold the two halves of the wheel itself.)
  5. Slide and wiggle wheel out past the exhaust.
  6. Do the above in reverse when puncture fixed.
Sep 25, 2010 | Peg Perego Vespa Scooter
Pride celebrity 4 wheel wont turn on
Hi
Gerry.
Nov 02, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Let me know
May 16, 2009 | Pride Mobility Victory 3 Wheel Electric...
Pride Celebrity Xl 4 Wheel Scooter Logo
13 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
