Question about Grundfos Comfort System Recirculator 595916
How do i bleed the zone of air? - Grundfos Comfort System Recirculator 595916
  • Grundfos Master
  • 5,245 Answers
How to fix a melnor 4 zone digital timer with stuck valves?
bleed the air out of each valve then re tighten bleed screw. if still stuck open then buy new diaphrams
Dec 13, 2015 | Melnor 3280 Digital Aqua Timer Watering...
All six zones run but cannot get one of the zones to completely shut off so I get a substantial leak so I turned of the system what should I look for
Hi Michael:
The solenoid for the leaking zone will probably have some debris in it. You could try to dismantle and clean it, otherwise, replace and you should be OK.
Cheerfuls.
Sep 14, 2015 | Rainbird Rain Bird Simple Set 6-station...
I'm using 2 zones, zone 1 runs fine, zone 2 runs for 5 min, loses pressure for a few seconds, then comes back on for 5 min. etc., etc.etc. Is this a valve or controller problem?
May have air in that valve. Check bleed air screw on side of vale and bleed until you get a steady stream of water then tighten back up.
Aug 01, 2015 | Irritrol Kwik Dial 4 Zone In
I have 3 zones on my boiler and I am trying to bleed the one thats not giving heat, no water comes out when you bleed it whats wrong 1 will not bleed
MAKE SURE THE PUMP IS ON AND VALVES OPEN CHECK IF AT LEAST AIR COMES OUT. THEN TOUCH THE PIPES AND SEE WHERE THE TEMPERATURES START TO WARM UP.
Feb 21, 2015 | Heating & Cooling
We have radiant floor heating system ran with /wirsbo valves. One zone is not working..not heating at all. The valve seems to open up when thermostat is turned on but not heating room. Any suggestions?
Are you able to isolate the Zone?
If you are able to isolate the Zone, is there anyway you can bleed air out of the system?
1) turn off the other zones and see if this one starts to heat up,
if not. Try to bleed Air out of the main header until it gets warm. If this does not work, do you have to manually add water or is it an auto fill system? Make sure that is working or manually add water.
Oct 30, 2013 | Uponor Wirsbo A3010526 Thermal Zone Valve...
Bleed cooling system
The generic method of bleeding air from the cooling system is to use a floor jack or other method and raise the front of the car as high as poss, then fill the coolant recovery tank full and run the engine until it just starts to overheat, high end of normal zone on gauge, then shut the engine down and run cold water over the radiator core, this will self bleed the system and the coolant will be pulled from the recovery tank, repeat as necessary, never let the recovery tank run dry or more air will be pulled into the cooling systeml
Dec 22, 2010 | 1998 Pontiac Grand Prix
Need to bleed air our of cooling system on 1992 Lexus SC400
The generic method of bleeding air from the cooling system is to use a floor jack and raise the front of the car as high as poss, then fill the coolant recovery tank full and run the engine until it just starts to overheat, high end of normal zone on gauge, then shut the engine down and run cold water over the radiator core, this will self bleed the system and the coolant will be pulled from the recovery tank, repeat as necessary, never let the recovery tank run dry or more air will be pulled into the cooling systeml
May 18, 2010 | 1991 Lexus LS 400
Just replaced the water pump.Now i dont have any heat from floor or defrosters. any ideas?
DID U BLEED THE COOOLING SYSTEM, U HAVE AIR IN IT. HERE IS HOW TO BLEED THE SYSTEM OF TRAPPED AIR.
Jan 29, 2010 | 1991 Cadillac DeVille
New radiator installed. overheating
Bleed the air out of the cooling system. buy a bleeder kit from auto zone. run vehicle untill all air is bleed out adjust fluid level accordingly.
Jul 08, 2009 | 1999 Chevrolet Blazer
Three of four zones, baseboard heat, warm house, why not fourth
Go to the last heater in the zone and look for a bleed off valve so you can get the air out of the system. you may have to bleed it off several times as the air works itself thru the system. usually there is a automatic air vent on the very highest point that the system has. Let me know if this helps and have a Merry Christmas
Dec 23, 2008 | Heating & Cooling
Grundfos Comfort System Recirculator  595916 Logo
76 people viewed this question
Top Grundfos Hardware & Accessories Experts
Gene Haynes
Mike Magnay
Mike Magnay
Are you a Grundfos Hardware and Accessory Expert? Answer questions, earn points and help others
