Question about Grilling
Gas burner pulsating - Grilling
2 Suggested Answers
  • 7 Answers
SOURCE: Ducane lp gas grill flame pulsates
Have you replaced the battery ? They do rust and lose contact over time outside.
Posted on Apr 17, 2010
Why does my 2000 Monte Carlo SS pulsate between 50-60 mph?
check the TPS sensor as it could have a bad spot in it. also the trans maybe going in and out of overdrive at that speed.
Aug 30, 2014 | 2000 Chevrolet Monte Carlo
When burners are set above minimal flame, the flame becomes yellow and pulsates.
u need to clean the side area of the oven,,need also to wipe in a dry cloth.
Jan 13, 2011 | Microwave Ovens
88 chev,350, stick,2wd, 3500, gas flows to
E.C.M control injector pulsation, with key on check for voltage at injector harness, then reverse test light at battery and check for ground at the other wire at injector harness, crank engine ground should have pulsation if none bad E.C.M,good luck,hope this was very helpful.
May 14, 2010 | 1988 Chevrolet C1500
Apr 14, 2010 | Char-Broil Commercial Stainless Steel...
Unit will not operate when turned on and a red light pulsates next to the
That blinking light is an error code. It will blink two different numbers such as three blinks, pause, then four blinks. Once you get the combination of blinks, look at the wiring diagram pasted on one of the panels for a diagnostic chart. It may help you pin point the problem area.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Feb 24, 2010 | Carrier 38CKC036 Air Conditioner
Oven gas keeps kicking on and off like it's pulsating and can smell gas
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 17, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
A friend has a oven that has been coming on with a bang. I've cycled it on and off cold and hot no problems when I was there. Pulled the botten pan out (it is quite worped from heat and dosn't fit that...
a lot of iffy things could be happening here..
verify proper amperage draw through the ignitor.. i believe thats a 3.2-3.5 amp system but check the label thats on the gas valve, it will have the ratings listed on there for sure. make sure amperage draw is in the middle of the range as some gas valves are less tolerant of low amperage draw than others.
it almost sounds like your amperage load may be on the low side, just enough to open the valve regularly but not open fully..
its on its way out if so..
the popping could be the gas coming into the oven slowly enough to NOT blow directly across the ignitor properly, (igniting it instantly if it were) and allowing it to pool in the enclosure some because of the low amperage draw through the ignitor, eventually firing with a bang..
yes the regulator vent could be plugged, but another thing is if you are on bottled gas/lp/propane for your source of fuel the regulator at the tank could be faulty also, causing the pulsing flame..
hope this helps,
best of luck,
ttfn
Nov 02, 2009 | Jenn-Air Ovens
SB81P Not powering up, fan pulsating?
Are you sure all your cables are hooked up correctly on your flat ribbon make sure the wire with the red line is in the #1 position. If this is correct try disconnecting the cable and power and it see if the problem goes away.
Mar 21, 2009 | Shuttle Computers & Internet
Oven burner pulsates
The gas regulator valve would also be my first guess. It seems to not be allowing enough gas into the system. When the top is on, only a small amount of fuel is required, and when properly mixed with the air all is well, but when you also put on the oven, the regulator won't allow enough gas into the system, so it's "burning lean". I'd get it fixed before it pulsates so bad that it actually blows out the flames and you're left with a propane smelling dangerous house.
Apr 06, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Grilling Logo
37 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
