Question about Burberry Clothing Accessories
Missing screw Need replacement screw for B 4061 3151/87 arm of sunglasses only
  • 28 Answers
Any local optical shop should have a aftermarket screw for these
Posted on May 29, 2014
2 Suggested Answers
SOURCE: my puppy destoyed both arms
try these sites for parts
ray-ban.com
sunglasses.smarter.com
opticsfast.com
bottomdollar.com
Posted on Sep 14, 2011
Tip
How to Repair Ray-Ban Sunglasses. ?Replace a lost or missing screw in your...
How to Repair Ray-Ban Sunglasses.<br />&bull;Replace a lost or missing screw in your Ray-Ban sunglasses with a small piece of wire. Push the earpiece back into place on the sunglasses and gently wiggle a small piece of wire through the screw hole. Pull the wire through the opposite end and push it back through. Push the wire through at least three times and use your pliers to twist together the ends.<br />Fill a small bowl with warm water and set your sunglasses in it. This is a quick trick for fixing loose frames. The warm water heats up the frames, making it possible to reshape the glasses yourself. Remove the sunglasses after a few minutes and gently bend the frames.<br />Hold the Ray-Ban sunglasses in one hand to replace a lens that popped out. Turn the sunglasses over, so that the front faces down and place the lens onto the back. Gently press down with your other hand, until the lens pops back into place.<br />Use an eyeglass repair kit to replace any missing screws. The kits come with several small screws and a tiny screwdriver. Line up the screw to the proper hole and gently screw into place. If the screw won't go in, it means that your screw hole is stripped and you need to use the wire method.<br />Seal broken parts with instant glue. For broken frames, apply a thin layer of glue to one side and push the broken piece back into place. Hold until the glue dries. Instant glue also fixes lenses for wireless frames. Apply a layer of glue to the bottom of the top piece and push the lens in place.
on Nov 07, 2010 | Clothing Accessories
Replacement arms
These guys can get authentic lenses and earpieces for Versace glasses. Send them a message here
http://stores.sunglassreplacementlenses.com/contact-us/
May 23, 2014 | Versace VE 4158 Sunglasses
Lost arm
then throw away and buy new ones
Mar 23, 2014 | Bvlgari BV 8022 Sunglasses
Replace missing stone
If they are a year or less they should fix those under the "year warranty" through the manufacturer.
Nov 23, 2013 | Bvlgari BV 8092B Sunglasses
My sunglasses, a Rayban wayferes is loose. Its arms has loosen and is not a snug fit anymore like when i first got it. How do i adjust it so that it will return to its original fit? Hope someone can give...
Hi if you take you sunglasses into any opticians and explain your problem, they are more than likely to tighten the arm for you for free as it is only twisting a screw that attatches the arm to the frame or if you have a tiny screwdriver you will be able to tighten it yourself,
hope this helps
Feb 20, 2011 | Clothing Accessories
The right arm "nub" has worn down and the arm
respected sir
the right arm nub can be replace pls visted your near by sunglassed show rooom ,it will be done in minutes
if your are satisfied with my answer pls vote for me
Nov 28, 2010 | Oakley Fives Sunglasses
Clothing Accessories Logo
74 people viewed this question
Top Burberry Clothing Accessories Experts
Da Doc
ray gallant
Are you a Burberry Clothing Accessory Expert? Answer questions, earn points and help others
