Question about Dryers
Miele T 8433C tumble dryer water problem - Dryers
rogrrabbit
  • 986 Answers
SOURCE: Miele Tumble dryer will not produce heat .
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Oct 15, 2009
  • 177 Answers
SOURCE: where is the reset button for the miele t200
there is no reset button for this unit. if it is not heating you may have blown your thermostat
Posted on Sep 05, 2010
hunter19_46m
  • 7482 Answers
SOURCE: my miele 4322 vent tumble
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It's located on the blower housing.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Jan 06, 2011
  • 3074 Answers
SOURCE: miele t224 tumble dryer is
http://www.maybenow.com/how-to-remove-the-front-panel-on-miele-dryer-q24016479
Posted on Mar 06, 2011
jdhnmi
  • 143 Answers
SOURCE: miele tumble dryer t294c moisture sensor what is the part code
Check this site out www.repairclinic.com and enter in your model number you should be able to find the part there .
Posted on Nov 24, 2012
How do I reset thermostat on miele t5205c dryer?
The heating element/assembly may have failed
Nov 25, 2017 | Miele Dryers
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
Hi my miele condenser tumble dryer t294c has started leaking water from inside machine and leaking onto floor has anyone any sugestions of the problem I'm getting thanks
you should remove the cabinet then pour water in and jumper the door switch and run and check where and which hoses are leaking if any? check ur water pump for damage and leaks
Feb 28, 2015 | Miele Dryers
How do you change a belt on a Miele Novotronic t220 tumble dryer.
You might want to post this in the dryer section. Have you checked youtube?
Nov 03, 2013 | Miele Novotronic T220 Electric Dryer
Miele t224 tumble dryer is broken. the problem is how to access the drive motor and drum
Mar 06, 2011 | Miele Novotronic T220 Electric Dryer
Tumbler is making wierd sound but the drum still turns and it gets hot
drum rollers/glides, may be the idler pulley:
ttp://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 02, 2010 | Miele T8005 Tumble Dryer
Where is the reset button for the miele t200 novotronic special tumble dryer please
Oct 30, 2009 | Miele Novotronic T1570C Electric Dryer
Dryers Logo
23 people viewed this question
Top Dryers Experts
