Please can you help me, I received fax error code ng when sending a fax from UK to France on canon MX470Fax go do not go through and report indicate. NG code in result column and mode G3
In the column mode it is indicated transmit G3 column pages 0 pages 0 result NG , the faxes is ringing and trying again but it is never sent it was previouly working well could it be telephone connection?
  • 186 Answers
SOURCE: fax not sending
It sounds like you have a problem with your phone line. If your machine has a reciever, pick it up or press the hook key. You want to listen to the dial tone. If there is any static in the line it will cause faxc problems. Also you can try disconnecting the fax and plugging in a standard phone into the wall jack. Make a phone call and aee if the line is clear or if there is static. If you do hear static in the line, first try replacing the phone line cord, from the wall to the fax, or phone. If that doesnt help then it is definatly a problem with the line and you must call the phone co. If the line is clear with the standard phone, and static with the fax reciever, or hook mode, then you may have a bad modem board in the fax. Let me know if I can be of further help! John
Posted on Sep 07, 2007
  • 2072 Answers
SOURCE: Cannot Send Faxes
Problem:
Not sending to long distance and government sites with encyrptor. Note: NG is not actually part of the Fault Code. NG stands for No Good on the Activity Report. Cause:
Not enough time to hand shake. Another cause of B5 can be a faulty Main PWB. Note: Should you wish to change the Main PWB, consult the following ETI 170535 to insure that you are selecting the correct part number. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. On speed dials and one touch numbers that the Customer is having problems with, you will have to modify the number to be dialed. What you have to do is add pauses to the end of the number. (example 555-5555 does not send to, error B0 (that is B Zero ) every time / then start adding pauses at the end of it until it works. Example 555-5555#. in some cases in Winnipeg and surrounding areas we have had to put up to 6 pauses to get a successful send. Note 1: These were to Fax Machines with encryptor devices and long distance...Avoid Call Backs. Inform the Customer of this. LEAVE instructions on how to do this. This will save your and your Customer some headaches. Note 2: Some success has been found by turning off the V34 Modem
Posted on Apr 17, 2008
SOURCE: MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Posted on Apr 25, 2008
leroyal
  • 2120 Answers
SOURCE: What does 'NG' mean on the fax activity report
NO GOOD (USA) or NOT GOOD (ASIA)
Posted on Jan 21, 2009
FixinFax
  • 3085 Answers
SOURCE: Brother IntelliFax 4100e unable to receive fax
It could be some senders are sending over a DIGITAL PHONE LINE. All fax machines are ANALOG.
Posted on Jul 20, 2009
Unable to send faxes Error code NG #018 appears
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Mar 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Every fax we try to send it comes up with a error tx report of "NG". What does "NG" mean and how can we fix it?
Hello.
NG means: Some or no pages sent.
Check the paper feeder to see if the page is pulling through.
Listen to see if the fax line "sounds"like it is working or if you hear dialing or not.
Hope this helps.
Mar 22, 2010 | Canon FAXPHONE L80 Laser
Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
Oct 07, 2009 | Canon FaxPhone L75 Plain Paper Laser
Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Jun 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Connot send fax
hi there!
thanks for using Fixya.com!
I suggest you try to call first the receiver and ask, perhaps they are having with their lines or fax machine. From your side, pls check with your Telephone provider for assistance.
In addition, pls check your cables, and connections.
Regards!
Pls. don't forget to mark!
Feb 18, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Sep 03, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon fax mp780 says 'ERROR TX REPORT' 'result NG', what do I have to do to to snd the document? The manual has no translation of error codes!
If you go into the fax tx settings and turn off ECM setting, the fax should send (at least it did for me when I had the same problem).
Jun 28, 2008 | Office Equipment & Supplies
Cannot Send Faxes
Problem:
Apr 16, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
19 people viewed this question
k24674
