Question about Miele Dryers
Water not draining to container,leaking.
I have a Miele T 8433 C Condenser dryer. It has been set up so water goes into condenser container. When load is drying the water is not going into container but has collected in bottom right of unit. All filters are clean. I think there may be a blockage in pipe from drum to container but unsure how to go about clearing it. Any suggestions? or do I need to call serviceman. Kind regards Effie
    New Friend:
  • 73 Answers
Undu the hose or pipe at highest level and make sure it is not clogged
Posted on Aug 09, 2017
  • 38 Answers
SOURCE: LG TD-C700E/40E/41E/45E Condenser Dryer
sounds like your condensin pump is leaking and triggering the over flow micro switch not a job 4 a novice call an engineer good luck
Posted on Jul 25, 2007
SOURCE: Hoover nextra mega load 7.5kg
On the rear there is a Heating element hidden under the silver cover, on the top of this unit, there is 2 thermostat's, one is a auto-reset set (On the left) around the 100'c mark and one is a single use thermal trip set at 130'c (on the right, also denoted by a blue spot), the idea is when the heater reaches 100'c is powers off until the air temp drops, once it drops the auto-reset kicks in and forses the heater to power back up, however, in the intrests of safety, if the auto reset fails to power down then the 130'c thermostat will permenently remove power from the heater and will illuminate the filter care light, the only way to restore the power to the heater is to either have an engineer replace the whole heater as Hoover/candy do not sell on the thermal cut out to anyone.
you can usually find the heater unit for £30-40, an engineer may charge upto £140 for the same part and fitting.
Posted on Jan 05, 2009
  • 3463 Answers
SOURCE: Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Posted on Jan 13, 2009
SOURCE: hotpoint CTD00 Tumble Drier: No water in draw, 3x as long to dry
sounds like pump has gone
Posted on Aug 31, 2009
  • 213 Answers
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
Hi my miele condenser tumble dryer t294c has started leaking water from inside machine and leaking onto floor has anyone any sugestions of the problem I'm getting thanks
you should remove the cabinet then pour water in and jumper the door switch and run and check where and which hoses are leaking if any? check ur water pump for damage and leaks
Feb 28, 2015 | Miele Dryers
I got a Whirlpool AW Z 865 dryer. It is a condenser dryer and the water is not going up to the collecting bucket, but remains below and then leaks out and floods the floor when I open the little pull door...
I had a similar problem with a Whirlpool AWZ 8578 Tumble Dryer. The solution was to clean the fluff out of the rubber grommet in the drain hole under the left front of the condenser. Then the water from the condenser could run into the collection container underneath.
Nov 25, 2010 | Whirlpool Dryers
Miele WT945 leaks water from internal drain
If it is the bottom hose on the condenser box leaking.
This is a vent.
It is most likely the condenser box is blocked with fluff and will require cleaning or replacement. I imagine the appliance is not drying very well if at all
Apr 02, 2010 | Miele WT945 Front Load Washer / Dryer
Miele T358C dryer. water not being pumped out of the sump??
In some cases cleaning the condenser out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, it is normal for there to be some water in the tubes when you do this, you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier for air circulation; and empty the water container often or reconfigure your pluming arangement to reduce the water left in the container. The circuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later :?) DRRXR
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
Feb 02, 2009 | Miele Novotronic T220 Electric Dryer
Indesit condenser tumble dryer water light always on even though container empty
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
Oct 06, 2008 | Dryers
Jul 25, 2007 | LG DLE2512W Electric Dryer
Condenser Dryer Still Filling Room With Moisture
all dryers produce moisture. thats what hapens when you heat wet cloths up. the dryers job is to remove the moisture to dry. thats how the automai]tic cycles work by deteting the moisture in the exhaust. i will say there is nothing wrong with your dryer. only thing i dont understand is the containers of water?
May 13, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
66 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Miele Dryer Expert? Answer questions, earn points and help others
