Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Biz hub c250 code error
It is reporting Paper jam on tray 2 a3 but it is not picking any paper.
  • Konica Minolta Master
  • 6,696 Answers
Clean the rollers for that draw
Posted on Jan 23, 2016
5 Suggested Answers
  • 523 Answers
SOURCE: Printer will not pick up paper and gives a paper
change or clean the pickup roller for the first tray, and make sure no small paper stucking on sensor , check the sensor if its on right place or not broken. and u will be fine.
Clean the pickup rollers by alchohol
Posted on Mar 09, 2009
taminol
  • 62 Answers
SOURCE: Biz Hub C250 - code error C2551
Ahhh, you must be the same Macdaniel I emailed for clarification a short while ago.
C2551 relates to the Cyan imaging unit, the machine thinks the toner level inside the Cyan imaging unit is low.
Opening and shutting the main front door is the reset procedure. However if this doesn't work you should try the following
Remove the Cyan imaging unit, give it a bit of a shake and then refit.
Experience tells me that the above only works on occasion and you will probably require a new imaging unit. They are available for around £250.
Please be aware that the fault could also be down to a circuit board being defective, but this is less common.
Regards
Taminol
Posted on May 26, 2009
SOURCE: Biz Hub c250 gives error code 3452
C3452: Pressure Heater Trouble.
Try to reset it like this:
Shut down from the main power switch (the one behind the front cover).
Keep pressed the Utility/Counter button.
Power on while the button is kept pushed.
Release the 'Utility/Counter' button only when you see the 'Trouble Reset' button on the touch screen.
Touch the 'Trouble Reset' button, a small ok should pop up underneath.
Power off, wait for a few seconds and then power on.
Posted on Aug 23, 2009
  • 44 Answers
SOURCE: error message sc36-05
Thats a low temp fuser code. You need to reset the code by going into "25 Mode" and reset dip switch 3-1 _ 1 to 0
Posted on Nov 29, 2009
Trying to print A3 full colour on my bizhub c250.2out of 3 times paper crashes at the oven and get the massage: misfeed detected, i remove the jam paper. but i would like to know what can cause this...
Fusing unit life is over or it can be the paper size problem.if you are using manual by pass tray for A3 printing then make sure machine is detecting A3 in manual by pass tray.if its OK then problem is in fusing unit.
May 31, 2012 | Konica Minolta bizhub C250 All-In-One...
13.01.00 Jam in Tray 2 error when no jam exists
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
Mar 24, 2011 | HP LaserJet P3005 Printer
I have a Biz hub C450. Tray 2 I have legal paper
go to service mode > system 1> marketing area
then choose europe button to fix that
Feb 04, 2010 | Minolta Office Equipment & Supplies
My printer keeps telling me to remove jammed paper, but there is no paper in it!! Help, and thanks!
OK do one thing off the printer then restart it.Reset the printer from printer option botton. then off again. After that when you on the printer then the massage naver come.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper stucked inside
Open the top cover.
Pull out the toner / developer units and look for paper under neath.
In the rear, pull open the access door.
remove the paper tray and look for misfed paper.
Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
It is sying i have a paper jam but there is no paper in it
There are two types of paper jams:
1) A jammed piece of paper at or near a sensor. Or a shred of paper is stuck under a sensor.
2) A paper feed operation that does not send paper into the printer will get reported as a jam it the paper does not reach a sensor in the time that is allotted to reach the sensor. The printer knows that the page is late and suspects a jam occurred prior to the sensor.
To determine if there is a “Pick” problem in the tray, place a mark (line or scribble) on the top sheet in the paper tray. Send a print operation to the printer. If a jam is reported, check the tray. If the marked page is still in the tray then you know the paper pick failed.
There are dozens of reasons for paper to fail to pick. The simplest fix to try is to remove the paper and fan it to remove any possible static charge causing the paper to stick together.
Don
Dec 12, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Error message sc36-05on my biz hub pro c 500, we cleared a paper jam now this error comes up
Oct 11, 2009 | Konica Minolta bizhub C250 All-In-One...
Bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Sep 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
29 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
