Question about HP Color LaserJet CM6040f MFP Q3939A Printer
30.01.41 error not functioning - scanner failure
2 Suggested Answers
marked
  • 6487 Answers
SOURCE: scanner failure error. Changed all
You can try this work around on your all in one printer, follow these steps.
1. Remove the cmos battery. How to:
2. Plugged the power supply into a power strip that has a switch to turn off power. Reason: So you'll be able to turn off the power from the power strip instead of unplugging the power supply from the wall all the time.
3. Disable ink level checking for both black and color. To do this, when you turn on the power from the printer. It should say Initializing. When it's done and it says the date. Press the left and right arrows at the same time. Then press the numbers 456. It should then ask you a Yes or No question. Press the number that says Yes. Then you'll press the two arrow keys again and this time you'll press numbers 789. A Yes or No question will appear and again you'll press the number that corresponds with Yes.
Sometimes this procedure doesn't work and you'll be required to remove the power supply from behind the printer. Once unplugged, wait 30 seconds before plugging it back in.
Posted on Sep 18, 2010
Whats the meaning of error E0202 canon ir copier
Description
An error occurs during the Scanner Unit (Paper Front) HP detection operation (outward).
E202 -0002 -04 Title Scanner HP error
Remedy 1. Connector disconnection/open circuit of the Scanner HP Sensor (SR2).2. Failure of the Scanner HP Sensor (SR2).3. Failure of the Scanner Motor (M1).4. Failure of the Reader Controller PCB (PCB1).
May 11, 2016 | Canon Office Equipment & Supplies
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
I have an HP m9050 MFP which gives an error 30.01.06-Scanner Failure whenever i touch the copy button and it all started after blowing and servicing
Based on the service manual a 30.01.06 Scanner failure:
1. With the MFP powered on,
verify that the fan is not
functioning.
2. Check for loose connections
and broken, frayed, or pinched
wires. Reseat the fan connector at
scanner control PCB location
J110, and connector J163 on the
flatbed fan.
3. Replace the fan. See "Flatbed
fan assembly" on page 154.
However print of a configuration page or event log and look at the past 30.X.X error codes make sure it's not jumping between a 30.01.06 - 30.01.10 as it could be something more than just the fan.
Oct 19, 2010 | Office Equipment & Supplies
Background changeover unit failure on 6130dj scanner. Tried cleaning it, rebooting pc & downloading driver . . . what else can I do?
When a background switching malfunction occurs, "F" and "4" will display alternately on the function number display panel of the scanner.
Wipe the top and bottom glasses located inside the ADF with the Cleaner F1 and check if the problem persists.
If turning on the scanner again does not recover the situation, then follow the procedures provided below:
1 Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2 Are the cables between the Control PCA and the BW Motor damaged? Or are the connectors connected correctly?
3 Is the white reference work properly? If not, then replace the BW Motor.Perform background changeover test.
4 Is the OPT Unit installed correctly? Check ADF (Front) and ADF (Back)
5 Replace the Control PCA and see if the error is resolved.
6 Replace the OPT Unit and see if the error is resolved.
Hope the above information is helpful.
Thanks,
ScanCare
Apr 26, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Nikon LS 2000 scanner is reporting a hardware error
Hello Mike,
According to a previous post this is your answer by:
johnmichaelc
The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
Oct 29, 2009 | Nikon LS 2000 Film Scanner
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Nikon LS-2000 scanner gives error 0x04620000
Stepper Motor Failures
Within the first 6 months of purchase I had to return the scanner twice to replace the stepper motor. The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
service required to fix stepper motor
Jan 07, 2009 | Nikon LS 2000 Film Scanner
Failure to align cartidge after inserting new one
It could well be that your scanner function is broken but hoepfully it is just malfunctioning, I would recommend trying to print a troubleshooting page from the system's menu to see if it lists any error codes regarding the scanner.
Dec 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
K80 "scanner Failure"
same problem here...error message says scanner failure - power off then on, but also doesn't work , ges what , id did buy the same in 2the hand , also same prroblem this is sh...
Jan 11, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Errors
Hi Jean, The issue can occure only when the HP printer is not gettting enough power supply or the scanner bulb is not getting heated up properly.. You can isolate the issue by directly connecting the printer to wall jack and powerup the printer and try to make a copy so that we can check the copy function as the copy,scannig and FAX use the same scanner bulb to performe all functions.. If the copy does'nt work try to lift the scanner lid and check if the scanner bulb is lit and the scanner machinasium is moving fine or not .. lift the lid and press scan button to check the functionality. If the printer is connected to a surge protector or power strip this will some time fail to provide the required power supply to the printer so connect it to wall outlet and check with the issue.. There is also a FIRMWARE UPDATE RELEASED BY HP to fix the some of the scanner failure and receving faxes issue with HP 6110 All-in-one Here is the weblink to download and install the firmware update just click on the link to open the download page and then click on download and select save to save the patch to computer and run it to install the update make sure that the printer is connected and turn on while installing the patch The link to download: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14700-3&lc=en&cc=us&dlc=en&product=79477&os=228&lang=en Hope this will fix the issue.. If the issue is with the scanner failure message try the instruction in the below weblink: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=us&lc=en&dlc=en&product=79477&dlc=en&lang=en Wish you success Jean Regards, Barret
Sep 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP Color LaserJet CM6040f MFP Q3939A Printer Logo
Seeker5211
Seeker5211
