Question about Sony SRS-BTM8/BLK Portable Bluetooth Wireless Speaker System - Black
Sony n50 wireless speaker not being detected
On my mac, cannot see the device in the list. tried to find a driver but failed. can some one help please.
2 Suggested Answers
  • 6 Answers
SOURCE: Sony NWZ-E435F driver cannot be detected in vista & xp
download sony nwz-e435f software through internet.i too had same problem but now it is solved now i can add video files
Posted on Feb 06, 2010
SONY CAMERA RATE MODEL NO.N50
To my knowlege, Sony did not make an N50 camera. They did make a VCR, the SLV-N50 and ratings for that can be found here:
http://www.amazon.com/Sony-SLV-N50-Stereo-VCR-SLVN50/dp/B00004VW2A
Nikon made an N50 film SLR beginning in 1994. 30 reviews on the Nikon N50 can be found here:
http://www.photographyreview.com/cat/cameras/film-cameras/35mm/nikon/n50-f50/prd_84794_3105crx.aspx
Hope that helps,
Bax
Oct 10, 2013 | Photography
No sound devices detected after hp update
you can try and do a system restore to before the new updates were installed, or you can go to hp's support website and look for your model laptop and download the newest drivers. i'm trying to determine if you have an hp or an asus, since you listed under asus. either way find out what sound hardware you have and download the new drivers or try system restore.
Jan 27, 2012 | ASUS Computers & Internet
I need speaker drivers for genius SP G06 computer speakers
http://www.opendrivers.com/categorycompany/17/11246/soundcard-genius-free-driver-download.html
There are 21 Genius Soundcard drivers and firmwares. The updated drivers and firmwares are listed for Genius Soundcard devices. The drivers and firmwares may be different based on the device models and operating systems. Some drivers and firmwares can be installed in different operating system, such as Mac OS or Windows.
hope this helps
May 21, 2011 | Genius SP-G06 Computer Speakers
IMovie 09 / Mac OS X will not recognise Sony DCR-HC35 via firewire or USB? Do I need to download the correct driver?
mac doesn't support usb streaming so that leaves us with firewire. it should be a plug-and-play connection. no need to install any kind of driver for the camcorder (but try to check if there are any available driver updates for the firewire card).if possible try to check if your computer firewire port is working by using other devices.your imovie software should detect the camcorder once connected.if not, disconnect cam, open imovie, and connect again.if still doesnt,RESET camcorder.if still the same try restarting computer with cam connected and powered on.check if you have a dv in indicator on your screen.check if firewire cable connection is secured.try diff ilink cable if available.if still no go, try a diff computer. if everything fails might also be a service issue.hope this helps.tnx:)
Apr 16, 2010 | Sony DCR-HC35E Mini DV Digital Camcorder
My wireless connection has gone down - internet connection is fine, AOL say I need to turn my wireless connector on but I didn't do it initially and don't know how to do it - help pls!
try a system restore first to the date when laptop was working fine with the wireless. if fails then uninstall then reinstall the wireless driver. if fails check if the wireless device still detected in the device manager. if fails then reseat the wireless card.
if you are using a wireless device thru usb then make sure the usb ports can read other usb devices just to isolate the case. if fails then do a clean installation.
Oct 21, 2009 | Computers & Internet
Jul 28, 2009 | Sony Audio Players & Recorders
I have problem with Wireless network connection (Intel PRO/Wireless 2200BG Network Connection) on Sony Vaio vgn-fs960p model. I'd reinstalled Windows XP Pro SP2, since that WLAN can't detect and connect to...
I suggest uninstalling and re-installing (which the operating system will prompt you to let it do automatically) the Intel PRO wireless device. That should do it. If you must provide authentication details in order to connect to a given access point (if it is Secure), then you'll need to do that again (manually) also.
Before doing so, make sure that you're running the DHCP (dynamic host configuration protocol) service. That's what enables wireless devices to get an IP address on the LAN to which you're trying to connect. Also make sure that the manufacturer's or your operating system's utility required to actuate the device Service is running.
To examine and modify (use caution here) system Services in Windows, Run the following command from a command line: services.msc
If User Access Control is enabled (it is enabled by default), it will prompt you for permission to run the MMC (Microsoft Management Console) required to change the state or setup of your system Services first. In order for the wireless device to connect it must both have said utility running (mine in Vista Business is called WLAN AutoConfig--make sure it's set to start in Automatic mode before you reboot).
To uninstall the device in Windows (Mac will be similar), right-click it from its listing the Device Manager (use Windows Help if you don't know how to run the Device Manager) applet and select Uninstall this device... You will also need to reboot because devices have "monitor/system level priority" and rebooting will ensure that the system will talk directly to the correct(ed) driver for the device.
Apr 07, 2009 | Sony Computers & Internet
Wifi adapter problem with my sony vaio
Try installing the original and update wireless driver.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNSR190EBQ
And
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C455228
Dec 14, 2008 | Sony VAIO SR Series Notebook PC...
Wireless Network stopped detecting ALL local networks
Hi, Have you installed the driver for your wireless card since you re-formatted?
Right click on my computer and go to properties, select device manager. all of your hardware will be listed there. are there any yellow question marks? these are devices that need drivers.
Your wifi card will probably be called 'network adapter'. go to the sony vaio website and download the right driver for your wifi card
Feb 20, 2008 | Sony VAIO VGN-N130G/W Notebook
PLAYSTATION 3 WIRELESS NETWORK
get a firmware update for ur router
Mar 29, 2007 | Sony Playstation 3 (PS3) Console
Sony SRS-BTM8/BLK Portable Bluetooth Wireless Speaker System - Black Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
