Question about Dryers
Miele tumble dryer - My Miele tumble dryer Novotronic T7634: the lights come on, I select the programme press start, I hear it click then nothing, the drum doesn't turn & there isn't any heat, a f
Lights are on, but will not start to tumble or dry
SOURCE: Not drying
I had the same problem with my dryer.
MAKE SURE THAT POWER IS OFF AND PLUG IS UNPLAGED AT WALL
On the back of the dryer there is a white metal cover in the centre with two philips screws. Once removed you will see metal box which has elements like a toaster built inside it.
You will see two sensors sticking out of top of metal box. The left one is the sensor for safety cut out in event of the dryer sensor on the right stopping working and letting the dryer overheat.
If you disconnect the left sensor 2 crimps and put multimeter on the left sensor two pins and if the meter beeps on continuety the sensor is ok. but if no beep the sensor is bad.
If sensor bad you can tempary bypass the sensor by joining the two cables together and try running dryer on a program and if heats up you know that you need to get new sensor.
WARNING! IF YOU LEAVE THE LEFT SAFETY SENSOR BYPASSED IF THE RIGHT HAND SIDE SENSOR MALFUNCTIONS THE TEMPERATURE WILL RISE AND CAUSE SERIOUS DAMAGE OR FIRE. THE PURPOSE OF THE RIGHT HAND SENSOR IS WHEN THE DRYER HEATS UP TO HEAT IT CUTS OUT AND WHEN DROPS DOWN IT HEATS UP AGAIN SAME AS AN OVEN.
You can maybe buy sensor from a meile dealer or RS COMPONENTS have the same sensor for £3.35 each.
NOTE: I ACCEPT NO RESPONSIBILY FOR DAMAGE OR INJURY IN MY ADVICE FOR REPAIR OF DRYER.
Posted on Dec 12, 2008
SOURCE: Dryer will not dry - drum will not turn
Just happened to mine also. The problem was that the Idler Pulley came loose from the drive belt. There is a switch on the idler pulley so that if there is no tension on it, the motor will not start and you will have the symptoms you describe. To reattach the Idler Pulley, remove the back plate surrounding the dryer exhaust. This will give you access to the Pulley. If the belt broke (unlikely with a new dryer such as yours), the fix is more involved. This dryer is the same as the Maytag MDE6700 - you can do a search for a service manual for that model and you can see the details. Hope this helps.
Posted on Jun 04, 2009
  • 198 Answers
SOURCE: Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
Posted on Sep 03, 2009
  • 66 Answers
SOURCE: Problem with Miele Touchtronic T 9800 Dryer end indicator
You've most likely got a bad control board. You'll have to install a new one which can be a bit expensive but cheaper than a new machine by far. I recommend getting a service tech to replace it for you however if your handy you could replace it yourself. Just get the new control board from an appliance parts store, they should be able to look up which board you need as long as you bring them the model number.
Posted on Dec 15, 2009
  • 177 Answers
SOURCE: where is the reset button for the miele t200
there is no reset button for this unit. if it is not heating you may have blown your thermostat
Posted on Sep 05, 2010
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
MIELE T7634 going into cool down after 2 minutes, what could be the problem?
check the exhaust line for blockage, sometimes lint will build up and cause the het to build up, socks or other items may end up in there. or colapsed line going to outside, or birds mice etc. may need to check the outside of pipe also.
Sep 23, 2014 | Miele T7634 White Electric Dryer 6kg, 15...
How do you change a belt on a Miele Novotronic t220 tumble dryer.
You might want to post this in the dryer section. Have you checked youtube?
Nov 03, 2013 | Miele Novotronic T220 Electric Dryer
Miele t224 tumble dryer is broken. the problem is how to access the drive motor and drum
http://www.maybenow.com/how-to-remove-the-front-panel-on-miele-dryer-q24016479
Mar 06, 2011 | Miele Novotronic T220 Electric Dryer
Miele novotronic T640 about 9/10 yrs old tumble dryer keeps stoping and the start button flashes when it stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 26, 2010 | Miele Dryers
Where is the reset button for the miele t200 novotronic special tumble dryer please
Oct 30, 2009 | Miele Novotronic T1570C Electric Dryer
The on switch will not turn dryer on
Hi everyone. I would be grateful for any help. I have a Miele Novotronic T220 tumble dryer. I cannot switch the thing on! The finish lamp is lit continually, and I cannot start another drying cycle.
I have unplugged the machine and pressed the start button again, but nothing happens.
Has anyone got any ideas for a technophobe.
Aug 10, 2008 | Dryers
Dryers Logo
87 people viewed this question
Top Dryers Experts
