Question about Music
SUPPLEMENTARY SERVICE ERROR - Music
KORG CX-3Combo Organ
DSP is Digital Signal Processor.\\
That is electronics and would have to be serviced by the company or authorized service centre
Sep 17, 2016 | Music
How to replace roland xp 50 keys And also repair outputs
Disassembly the unit.
Your question is less detailed. If the keys is broken,replace with new.
If you mean "How to",then you need the service manual.
Outputs problem,usually causes by output IC (or input IC) is defects.
It also can cause by AD/DA IC is error.
Mar 15, 2015 | Roland Music
Yamaha R100 reverb Processor E4 error code
Best advice would come from Yamaha itself. Here's the link to Customer Service-
Contact Us Support Yamaha United States
Nov 19, 2012 | Yamaha Music
DVD Recorder MODEL no.DMR-EZ27EB has U99 on screen unable to operate it
Hi.
U99 is a general communication failure between processor and timer, and there may be different causes. Common cause is a defective disk. Removing disk from the drive sometimes may fix the problem.
The first reset that you can attempt is disconnecting power for two minutes.
I quote below a post that was originally published in the MyCe forum (here):
"According to the service manual the U99 error is specifically a "hang up" displayed when there is a communication error that has occured between the main microprocessor and the timer microprocessor.
With more than twenty Panasonics (including four DMR-ES15 models) I'll offer my own observations:
There can be any number of causes for the U99 error, including a culmination of reading, writing, finalizing errors--sometimes appearing after U61 or U88 reading errors. The U99 error might also be associated with unusual DVD Drive noises, "grinding" indicating a dirty rubber hub and spindle; "clunking," "chugging" or "errrp" noises indicating a dirty lens or a failed laser assembly (the "optical pick-up").
Initial remedial measures include the routine DVD Drive lens, rubber hub and spindle area cleaning described in other CDFreaks/MyCE and AVS Forum threads. If that does not correct the problem(s) laser assembly or DVD Drive swapping with a direct replacement may be indicated. Also check for a disturbance to a ribbon cable or ribbon cable contact, correct or repair as necessary.
If the Digital PCB has become problematic, model-specific replacement is indicated. If the DVD Drive on-board contoller (if so equipped) has become problematic, model-specific replacement is indicated. In most cases "model-specific" means the same model year DVD Drive and, with problematic Digital PCBs or DVD Drive controller boards, replacements should be from the same model year and the same or very similar model recorder. Laser assemblies should only be replaced with the same model, i.e., 3331A and 3332A "optical pick-ups" might not interchange satisfactorily.
The U99 error may also be displayed when inferior media is in use. (Beginning in 2008 I've used nothing but Taiyo Yuden 8x Premium Line DVD-R media in my Panasonic, Philips and Magnavox DVD Recorders and HDD/DVD Recorders.)
The U99 error may also be displayed when there is an operating system "time out" occasioned when the user attempts to move too quickly between digital and analog channels (in 2007 and newer EZ series models)."
Apr 26, 2011 | Music
When i turn on my Ensoniq SQ2 it either says Unexpected Event ID 144 or it boots up and plays random notes or when i play notes only a handfull work I looked at the service Bulliten about the problem but...
I'm guessing this is a main board problem. You can get the SQ-1 Service Manual (parts as well) here:
www.syntaur.com/ensoniq_manuals.html
The Service Manual is for the 61-note SQ-1, but that uses the same boards as the SQ-1, just a different keybed. I don't think this is a keybed problem. You can try unplugging the ribbon cable to the keybed from the main board, boot up, and see if you get the same crash. You may get a KEYBOARD CALIBRATION ERROR message, but you can ignore it; if it boots, the keys won't work, but at least you'll be able to see if you get that error message. If you still do, you know it's a main board problem and not anything to do with the keybed. And at that point, your only hope is to replace the main board.
Jan 28, 2011 | Music
What does it mean when u get a service error on a tascam cd rw5000 cd recorder
I recommend contacting Tascam at this link:http://tascam.com/contact/support/ Describe your problem. As far as I can tell there were some problems with the media you could use. This article might help:http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000 You could also try contacting Sweetwater Sound and ask:http://www.sweetwater.com/sweetcare/ They have a great staff.
Oct 18, 2010 | Tascam Music
How can I get an owners manual
From this official link you can get the owners manual (170 pages)
From this official link you can get the supplementary manual (16 pages) for devices without cd drive unit
From this official link you can get the supplementary manual (28 pages) for devices with cd drive unit.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 17, 2010 | Fostex Mr16hd 16 Track Digital Recorder
Getting an error message when starting the PSR 2100
I would do a factory reset. Search Google for: factory reset PSR 2100.
It will be holding certain buttons or keys down when powering on.
Sep 18, 2009 | Yamaha Music
USB not saving audio. It gives CPU out of memory error.
Don't have too many folders on a flashstick try keeping everything into four folders maximum and I think you'll find it works perfectly.
Good Luck
Dec 21, 2008 | Peavey 32fx USB 32 Channel Mixer
Music Logo
12 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
