Password for tcl L42m61AZ to retune channels
Password to retune channels
5 Suggested Answers
  • 3 Answers
SOURCE: I have a TCL L42M61AZ
A firmware update from TCL will fix the problem. Call them and they will send out the firmware and a serial cable (required for update) for free.
I did the update yesterday and it fixed the problem (sound but no picture).
You will need a PC or laptop with a serial port (RS-232).
Posted on Feb 08, 2011
Testimonial: "Great to actually have some information as to how to solve the problem. The manufacturer should actually have this information on their website."
  • 1156 Answers
SOURCE: unlock code TCL L42M61AZ
Hi,there are two types of TV lock.
Child lock ,
TV code lock.
child lock If you had not set the password, try using the default password, 0000 or 1234. If not call the service centre for technical assistance.
TV code. TCL Color Television
· Simultaneously press "DISPLAY" button on remote handset and Volume- button on the front panel of television receiver for 6 to 8 seconds to get the various service menus.
· To access any parameter , use Up/Down keys of Program/Channel
· To change value of any Parameter, use +/- keys of Volume
· To exit POWER switch off the set.
Hope it helped..
Posted on Jul 10, 2011
rons_dear
SOURCE: TCL LCD TV L24D10F Channel locked; need password
how to upgrade my tcl lcd tv l24d10f? can u give me a firmware?
Posted on Jan 02, 2012
SOURCE: TCL LCD TV L42M61AZ
i have the same problem found you can try turning it off and on for ages to get it to work or place a heat source at the rear of the tv for a while and it seems to work. I have also used a hair dryer with success
Posted on Jul 06, 2012
I accidentally locked the channel of our tv and it was asking for a 4 digit password nobody know what the password is, how can we unlock the tv?
First of all, read the manual that came with it, and if you don't have the original, look online for it, and search for the default PIN number(usually 0000, or 1234). If it has been manually changed by a previous owner, try asking them. If that doesn't get results, see if there is a Master pin # for the TV, and enter that through your ORIGINAL TV remote. Sometimes Universal ones work, but I wouldn't hold your breath. I have an ex-hotel flatscreen Philips, and it took me ages to find out that it had a Master Remote, and a secondary one for guests, and the Master one could alter the functions, like lock out the HDMI plug(to discourage plugging in your laptop, and force you to watch PPV TV, oh, yay), and I finally tracked down the master unlock for it.
Another option is, if it's a digital TV box, contact the manufacturer, and see if they can help, in regards to resetting the unit to factory settings. It will mean you will need to retune your TV to get the channels, but at least you can then chose your own passcode.
Hope that helps, and cheers from New Zealand! ;)
Pete
MegaByteMe
Feb 10, 2016 | TCL L32D20
Retune TCL TV in Queensland 28/10/2014
Refer its user manual for details. If you haven't the user manual, try the site linked here. www.retrevo.com/
Oct 28, 2014 | TCL 24 in. Hdtv
PASS WORD PROBLEM
It is possibly a setting somewhere set when you did the re-tune, causing all of the channels tuned to be protected. try looking through your TV's settings for something that might help. Otherwise, we could really use a brand/model # to help you out any more.
Feb 15, 2014 | Toshiba Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Oct 24, 2011 | Televison & Video
I have a TCL L42M61AZ LCD TV. I find that the "Channel 9" programs in Adelaide, Australia, namely GEM, GO and Channel 9 DTV will not show a visual picture, only play audio. All other programs are...
Jan 26, 2011 | Televison & Video
Need to retune free view as has never been done since buying
Hello
To retune your Lg tv, do the following. At first connect the antenna socket at its back side with antenna firmly.
hannel Search
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
Jan 14, 2011 | LG 42PX5D 42 in. Plasma HDTV
Problem retuning syncmaster 933hd tv
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Oct 01, 2009 | LG W2353V-PF 23' LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
