Question about Maytag Refrigerators
Freezer is snowing up and vents frosted - won't stop running
Fresh produce area is cold... freezer snowing up and vents are iced - won't stop running
  • 46 Answers
Thermostat is malfunctioning and needs to be replaced.
Posted on Feb 08, 2014
4 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: Freezer is producing"snow" and freezer burning everything
AFTER A DEFROST,HAVE A GOOD LOOK AT THE DOOR RUBBER. IT MUST BE 100% SEALED FOR A FREEZER. (SHOULD ALSO HEAR A SLIGHT VACUME WHEN DOOR IS SHUT WHEN UP NTO TEMP).ALSO MAKE SURE MOTOR IS SWITCHING OFF AT +/- 20C (TEMP).IF ALLOWED TO RUN CONTINUOUSLY TEMP WILL PULL DOWN TO CREATE EXCESS FROST.
Posted on Jul 20, 2007
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
whytfang
  • 170 Answers
SOURCE: Kenmore Trio bottom freezer frost free. Producing frost
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Posted on Mar 26, 2009
Freezer part are too cold
Why is my freezer too cold? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
The freezer freezes the food rock hard. There is frost throughout the freezer part. Today I noticed a half inch of ice on the bottom of the freezer. I cannot slide out ...
[Appliances] Freezer is too cold? - Home Improvement ' DSLReports ...
www.dslreports.com > ... > Home Improvement
DSLReports
Jul 31, 2014 - 16 posts - ‎12 authors
I'm guessing food won't last as long if it's too cold? ... Freezer is too cold? I get a build-up of ice in some of my frozen items in my freezer. .... If no recent changes, then maybe you are seeing only part of the frost build up. Maybe ...
Freezer to refrigerator vent frozen (1) - YouTube
? 1:30
https://www.youtube.com/watch?v=8g_39UHYeEA
Feb 9, 2012 - Uploaded by Dal4us
Our freezer was getting too cold and refrigerator was not cold. ...Refrigerator Repair - Fresh Food Section Is Not Cooling , Kenmore , Whirlpool ...
Jan 03, 2016 | Whirlpool W8RXNGMBD Universal Silver 17.6...
Freezer working fine, fridge not at all
Brand name and model would help but here is a guess. Most frost free refrigerators have the main cooling unit in the freezer area side. To get the fresh food side cold, there is a small fan in the freezer side that blows cold air to the fresh food side through a duct work or trap door. If that fan stops or fails for and reason, the first place you will notice the temp rise is in the fresh food section. See if you can hear the freezer fan running. You may need to push in the door switch for the freezer light to hear the fan because they sometimes run the fan wiring through the door switch. It may stop when door is opened.
Apr 03, 2015 | Refrigerators
Amana BR22VL refrigerator section stopped cooling.
is there any frost on your food packages or on the ceiling where the light is?if so the door was left open and the air vents are froze up or you have a bad damper or evaporator fan motor,open the freezer door,do you hear the fan blowing?if so the fan motor is good,check for ice on the ceiling and packages,if that checks good look at the back inside wall of the freezer,if that's covered with like snow or frost you have a defrost problem or also you have a damper in your model,it's closed and won't open to let the cold air in from the freezer.
http://www.repairclinic.com/PartDetail/Damper/R0161050/223353
go here,this is the part,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer up into the fridge section,in your model the damper door opens to let the cold air in,when it gets cold enough the damper closes and that's it,so if the door wasn't left open and the fan is blowing in the freezer you have a bad damper.
Aug 10, 2012 | Refrigerators
Refrigerator warm freezer too cold
If you have already adjusted the controls for temperatures in both compartments and allowed 12 - 24 hours to stabilize and the trend is continuing, there may be a problem with the fans that move the cold air from the freezer to the fresh food compartment. The fridge may also start allowing temperatures to rise in the freezer soon, too.
All of these problems originate in the freezer compartment, where the cooling is done. Behind the back wall; inside the freezer - lies the cooling coils, defrost heater, circulating fan(s) and defrost terminator sensor. Unplug the fridge. Empty the contents of the freezer, remove the ice maker assembly and the back wall plate and you should see these components. If it looks like a large block of snow and ice, the problem is with the defrost circuit components. If clear with a minimal amount of frost, the warm fridge is the result of blocked or limited airflow from this area to the fresh food compartment - likely a failed circulating fan. Plug the fridge back in and check to see if the fan is running - since the fridge is warm, it should be running. The fan or the thermostat will probably need replacing if it is not.
If icing or frost is the problem, you'll need to isolate and replace one or more of the following: defrost heater, defrost terminator or defrost timer. The last two are the usual suspects for this type of failure - but the heating element can fail too. Many times, the defrost timer is accessible from the front of the fridge, behind the kick plate below the freezer door on the right side. Other times it is located in or near the temperature control area.
Jun 18, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
It's snowing in my freezer!
it's not the filter. is there frost on the inside lower back of the freezer. or is it around the edge of the door are your ice cubes fuzzy can you here the fan running in the freezer
Jun 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fresh food refrigerator not cold, freezer OK. Air grills not blocked & coil at the base is clean. It has been 3 hours & no cold air circulating & is warm inside fresh food area. Motor shuts off. No manual...
Have you checked to see if the freezer fan is running? Have you tried turning the unit off and giving it a 48hour defrost with both doors open? this may fix it if there's ice in the fridge vents. Is there alot of frost on the back wall of the freezer? cheers
Mar 26, 2009 | Maytag MBB1954G Bottom Freezer...
Freezer wont stop running
check that the dispenser flap is sealing properly as an air leak here will produce frosty snow
Aug 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing enough and fridge not cold enough
Hello Scott, remove the food from the freezer side and remove the rear freezer panel. You will see a coil and it should be completely frosted over. If not then you have a sealed system issue. If it is froze solid in frost where you cannot even see the coil, then you have a defrost issue. You should have a little frost on all the coil, the defrost is what clears the frost so the evap fan motor can circulate the air thru out the unit. If frost is good, push the light door switch to start the fan. If it isn't running check for 120 volts. If it has voltage, but not running, replace the motor. Hope this helps.
Aug 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
89 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
