Question about Toshiba 62HMX95 62" HDTV
Color wheel was newly installed
How do I adjust color on my tv?
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
no you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Dec 29, 2013 | Samsung Bp96-00674a Dlp Tv Color Wheel...
Samsung DLP HLS4266W
Check the fittings of the color wheel. Refer this site for more details.
May 17, 2013 | Televison & Video
I am thinking about buying a Samsung 72" DLP (Hlt7288wx/xaa) for $500. The seller says a tv repairman says it needs a color wheel replacement. Do you think this is something that would be difficult to...
Yes,tvs with a colors wheels design into it are more prone to brake down and more quickly than tvs without colors wheels design into it.The colors wheel in the tv spins at 12000 RPM at every cycles to make and let the tv Light Engine shine a beam of light into a colors wheel to make and have a colors spectrums to make it to works for the tv.No projection tv with a colors wheel are not easily to be replaced have go through alot of trouble to replace a colors wheel itself.The tv colors sit way back of the tv have to take out many tv mechanical tv frames bulk heads even than can come to the tv colors wheel itself to replace it.Take ur $500 buck buy a "40 LCD tv less worry less head aches.
Aug 22, 2011 | Samsung HLT7288W 72" HDTV
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
I have a magnavox big screen tv that was giving to me. i do not have the manuals with it. when i turn it on. the color is in three demension I cannot get it adjusted where they colors are all together.
hi,
first of all check the tint setting on your TV picture menu.
if not get the correct color then, your telivision is a dlp TV that means it have a color wheel in side. if the synchronization of color wheel is not correct this problem can occur. there is a sensor for counting the rpm of color wheel. also have a black mark on the color wheels rotating portion. the sensor scene this black mark for making count. if there is any dust in that portion it will make difficult to the sensor making the counts. you have to remove the color wheel to clean the same.
ok
Feb 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Rattling sound from the Samsung DLP TV
Your Color Wheel is bad and needs to be replaced by a trained Samsung tech. There are adjustments that must be made after the color wheel is replaced. Part# is BP96-01579A
Jul 15, 2009 | Samsung HL-S5087W DLP TV
DLP Image
In some cases,after installing a new color wheel, the speed of the wheel motor must be adjusted to obtain proper speed to ensure a satisfactory image. Unfortunately, you can not and should not attempt to do this adjustment yourself as the service menu contains many adjustments which if accidentily mis-adjusted may cause irrepairable harm to your TV. Ask a local samsung servicer to do an "index delay" adjustment in the service menu.
Jan 19, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
About the color wheel option
Hello Brandon B,
look on the side of the unit there will be a sticker with Model number, serial number and Version code. The version code will tell me what color wheel you need. There maybe some CCA adjustment you need to do using the remote in Service mode. Let me know what the version number. We will go from there. You can contact www.interactiverepair.com they will walk you through the installation process
Best regards
circuitcity
Jun 23, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color wheel replacement
I have the same problem. Iet me know if you get a solution.
Brandon
brand43076@charter.net
Apr 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
RCA HDLP 50W151 scenium color wheel
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Apr 07, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Toshiba 62HMX95 62" HDTV Logo
16 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
