Question about Dishwashers
Fix a GE 1200 potscrubber portable dishwasher
I turned my portable potscrubber 1200 GE dishwasher on it was running great then on drain cycle water started coming out the bottom of it how can i fix this? Please help me.
  • 35 Answers
SOURCE: dishwasher not draining fully
Remove and replace the motor / pump assy. Call technician. Big Job
Posted on Dec 09, 2007
  • 1314 Answers
SOURCE: Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Posted on Dec 31, 2007
  • 90 Answers
SOURCE: 18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Posted on Jan 05, 2008
SOURCE: dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Posted on Apr 26, 2008
SOURCE: GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
Posted on Aug 01, 2008
I have a GE 1200 Potscrubber portable dishwasher it was running good until it started to drain then water started coming out the bottom is there a way to fix this? Please help me.
You can take the unit and lay it down. There will be some water leakage. You can then see the hoses and connections. Sounds like the drain hose is either cracked or loose.
Feb 08, 2014 | Dishwashers
Dishwasher won't drain at the end of the cycle
Whenever an appliance does operate its pumps/valves heaters correctly for part of a cycle then doesnt at another point, it is a problem with the controller of the sequence in the cycle.. On older devices this can be a rotating knob that slowly runs to end of cycle triggering events as it turns, by tripping blade switches near the rotating item. On these the switch trigger points can be inspected and sometimes repaired. On newer items the cycle is controlled electronically, and you have to replace the whole control unit, which is usually a large expensive part that includes the display and all buttons. Try getting a used control unit from Ebay and swapping it out, or consider replacing the whole appliance.
Dec 14, 2013 | GE Dishwashers
When the water drains at the end of the cycle, water drains from the bottoom of the dishwasher, around what looks like an actuator arm? not exactly what the model # is all i know is it is a GE potscrubber...
Hi, I have seen this a lot when I did maintenance work for apartment communities.The part to fix this depending on modle was $85-$125 six years ago, I would just replace it.
Mar 05, 2011 | GE Dishwashers
Is water suppose to stay in the sump pump of a ge potscrubber dishwasher. The water drains except in the very bottom where I guess the pump is. There is lots of mildew and I have lots of grit on my...
Yes water does stay in the sump all the time. This is normal.
Try running a cycle with a cup of Vinegar or Baking Soda in the dishwasher.
Also check to make sure that your drain line (under the sink) is higher than the sink drain and not allowing some sink drain seepage back into the dishwasher.
Jun 20, 2010 | GE 24 in. GSD2230Z Built-in Dishwasher
My GE Potscrubber 1200 cuts on perfectly and
probebly you dont have enough water coming in start the dishwasher,when it starts washing dump a bucket of water in the tub.if it starts moving replace the intake valve
Feb 26, 2010 | GE Dishwashers
I have a GE Potscrubber dishwasher that only hums, won't run
I have a portable that had the same problem. I called a repairman and he turned a fan blade on the motor. Mine is located on the right side about 12" in. It gets hung up when it is run often enough. If your problem is the same is mine all you have to do is turn the blade and it works like a charm. Hope this helps.
Feb 18, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
GE POTSCRUBBER 1200 DISHWASHER
I have a Ge Potscrubber 1200. Fairly new I guess as I bought it with the house that I purchased 1 1/2 years ago. Sometimes it drains and sometimes it does not. Today there was two inches of water! About to remove the bottom panel. Sounds like the drain valve it blocked but not sure. Any thoughts?
Apr 14, 2008 | Dishwashers
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
Owen Barnes
