Question about Toys
2520 tractor grinds gears in reverse - Toys
  • 138 Answers
SOURCE: Transmission reverse and 1 st gear, 20 hp
transmission and shifting problems are tricky. from the limited information given, i'll go on assumptions - if this is a hydrostatic transmission, your brake is stuck, it will need to be adjusted - if it is a six speed, several factors come into play. if it will shift okay with the engine OFF, but not with it running, you have a belt problem. has the belt been replaced recently? is it the correct belt? is the belt routed correctly? if none of the above, check the belt guides to make sure that a stick or something hasn't poked up there and bent them. their purpose is to make the belt "blossom" away from the engine pulley so there is no tension on the belt at the transmission. if it won't shift with engine off, the shift shaft in the trans is probably rusted and sticking.
Posted on Aug 16, 2009
mickey813
  • 472 Answers
SOURCE: my craftsman lawn tractor has a 42 in. deck, w/21
YOUR TRANS IS BAD
Posted on Oct 02, 2009
mickey813
  • 472 Answers
SOURCE: Troy bilt lawn tractor that will not go in forward-just grinds
sounds like the trnns has some thing lose in it you will need to get to the shop
Posted on Oct 15, 2009
  • 156 Answers
SOURCE: tractor won't go in low gear or reverse
I had the same problem and replaced the shifter which I found at
http://www.mypegperegoparts.com/switches.html.
This fixed all the speeds and now it runs great.
Hope this helps
Posted on Jun 08, 2010
adamfjeld
  • 1508 Answers
SOURCE: it wont go in reverse or gear 2
do both wheels spin in 1st gear?
Posted on May 22, 2012
Where do I find the starter soleniod on a 2007 2520 John Deere?
Peter, To find the solenoid, just follow the positive cable from the battery to the solenoid. The solenoid may be mounted right on the starter of your tractor.
Amazon com Starter Solenoid 12 Volt 3 Terminal Intermittent Duty Denso...
NEW STARTER SOLENOID JOHN DEERE UTILITY TRACTOR 2040 2240 2520 4400 820 920
Apr 11, 2016 | Garden
The 2520 has a loss of power in high gear under a load
that should have the yanmar in her, could be a few things, first off i check or change fuel filter, could also be a clogged injecter or a injector not working, but fuel problem is my first guess is filter is old and block, also a good time to drain and remove any water as well
Mar 12, 2014 | John Deere 420,1020,2010,2020,2510,2520...
What is it when in reverse the automatic transmission on a 1999 Camaro grinds?
Reverse is not "synchronized" forward gears are, so it does make some noise, try shifting to 2nd before engaging reverse to slow gear rotation and limit gear clash or grind.
Oct 08, 2012 | 1999 Chevrolet Camaro
Grinding gear going into reserve
There is no syncro mesh for reverse gear. However, if you put the car in 3rd gear before engaging reverse, it should go in every time. Good luck..
Aug 02, 2012 | 2006 Mini Cooper
Troy built differential problems
check the linkage and make sure its all the way into gear
Apr 30, 2012 | Mtd Garden
Sep 05, 2009 | Garden
Troy bilt pony riding mower will go in reverse but grinds in forward where do i start
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
Jul 17, 2009 | Garden
Grinding when in reverse and tries bogging down at lights
stop shifting so hard. your reverse gear is the same exact gear as your first, so if you shift hard and grind that gear a little then reverse will be harder to get into. you probably need your transmission rebuilt the harder your engine has to work the more its going to bogg down
May 14, 2009 | 1987 Ford Ranger
Toys Logo
11 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
