My Toshiba AW-8970S washing machine makes loud noise and hangs while draining the wash cycle water from the tub
jsrock516
  • 5911 Answers
SOURCE: Loud clicking noise at spin cycle
It sounds like you have a motor coupling that has gone bad. Most of the Kenmore top loaders that I'm familiar with are direct drive machines. Which means, they use a motor coupling between the electric drive motor and transmission to run. If you are in the habit of doing heavy loads like comforters, blankets and jeans this can put a heavy burden on the motor coupler and wear it out faster. The coupler is designed to take the burden of the punishment in order to protect the transmission and drive motor and it is common for them to wear out. The coupler is fairly easy to replace and usually runs about $15. It is located inside the machine between the drive motor and transmission under the wash tub. You would have to remove the outside machine casing, the water pump and drive motor to get to it, though. Make sure the machine is unplugged before attempting any repairs involving removal of the drive motor. If you are not mechanically inclined, you may want to seek the aid of a repairman. I hope this helps.
Posted on Apr 29, 2007
  • 4 Answers
SOURCE: Wash machine agitates but won't
Yes, the problem is the pump filter which is hidden behind the lower front panel. To access the filter, unscrew three screws at the bottom of the panel and carefully remove the lower front panel. Make sure to unplug the machine. With the panel removed you will see the pump filter. Get a bucket and some towels ready, because when you open the filter, you may get a gallon plus of water coming out. GE failed to put this in the use and care manual for the 6260. But low an behold, GE put an access door and explicit instructions on cleaning the pump filter in the updated 6400.
You may have burned out your washer pump. That is what happened to me. The machine would not drain or spin properly and so I kept pushing the blinking start/pause button to get it going again. Then it finally did not drain at all. I installed a new pump and with the cleaned filter, the machine worked like new. For some, simply cleaning the filter allows the pump to work properly. As the filter gets clogged the pump has to work harder and harder to pump out the water. When this happens the cycle times get extended . One symptom of a clogged filter is the final minute (spin cycle) takes much longer. Obviously this is a "design flaw" that GE "fixed" in the recent version of the 6260.
Posted on Nov 18, 2008
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
sclarke7
  • 222 Answers
SOURCE: Kenmore Washing Machine 82110 - Loud Noise
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Posted on Apr 07, 2009
  • 555 Answers
SOURCE: My kenmore HE 2 Plus washing machine makes a loud
Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
Posted on Aug 31, 2009
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
https://removeandreplace.com/.../washing-machine-making-noise-during-the-spin-cycle-...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Nov 18, 2017 | Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
Washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor
If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
Jul 20, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Water draining makes loud noises
if water isn't draining properly the cycle will stop thereon check the drain pipe
Oct 12, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
