Question about Argus Roundabout 909 100 35mm Film Slide Rotating Carousel Tray Projector Mint
Case removal? how do I remove the case to service the cooling fan?
How do I remove and replace the water pump on a 2006 Chrysler 300 hemi 5.7 l.
5.7L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect negative battery cable.
  3. Drain the cooling system.
  4. Disconnect negative battery cable.
  5. Remove the upper radiator hose.
  6. Disconnect cooling fan electrical connector.
  7. Remove cooling fan mounting bolts.
  8. Remove the radiator cooling fan assembly from vehicle.
  9. Remove the radiator fan assembly.
  10. Remove accessory drive belt.
  11. Remove thermostat.
    NOTE The water pump mounting bolts are different lengths. Note the location of the water pump mounting bolts.
0996b43f80200d65-mw3da2o1okphbx00ygfzxzdl-4-0.jpg To install:
  1. Install water pump and mounting bolts. Tighten mounting bolts to 20 ft. lbs. (28 Nm).
  2. Make sure double ended bolt is in the proper location. Tighten double ended bolt to 20 ft. lbs. (28 Nm).
  3. Position the radiator cooling fan assembly in vehicle.
  4. Install cooling fan mounting bolts. Tighten to 50 inch lbs. (6 Nm)
  5. Connect the cooling fan electrical connector.
  6. Install the upper radiator hose.
  7. Install thermostat.
  8. Install the accessory drive belt.
  9. Install the radiator fan assembly.
  10. Connect negative battery cable.
  11. Fill the cooling system.
  12. Pressure test cooling system.
Mar 16, 2017 | 2006 Chrysler 300
Cooling fans A2121
you will need to remove the battery remove the top casing where keyboard seats once thats remove you will be able to see the fans and can be remove pretty easy.
Feb 05, 2013 | Apple MacBook Pro 17" Intel Core 2...
My double Cooler Master Cooling Fan R4-S4S-10AK-GP that i use underneath my laptop stopped working even though its not been in use for long time i bought it as part of a cooling pad with removable cooling...
If the fan spins and you find there is power going to it, then likely the electronic drive circuit has failed. You can get replacement fans at stores like Fry's and other sources.
Aug 03, 2011 | Cooler Master R4 Series Silent 140mm Case...
My n4030 dell cooling fan is stoped and before that it was very laod amd noisy so i want to open cover may be ther is somthing is blowin it up
The good news is that you will get to open that case.The bad news is you will open the case to replace that fan.
Remove the power cord.Then open the case.Make sure you do NOT do this while standing on carpet or a rug.Before you touch anything make sure to touch some one or some thing to discharge static electricity.Now use a small screw driver and remove the 4 screws that hold the fan down.Now gently lift the fan out and put in the new one.Screw it down not to tight or it breaks the fan.Put the case together and you are done.
May 16, 2011 | Dell (6F858) Cooling Fan
I have a compaq laptop and my cooling fan stopped workin how do i get to it?
You will have to open the case. This is normally done by removing the plastic strip above the keyboard, removing the keyboard, and then opening the case.
Most laptops have screws on the bottom of the case. In some models, the keyboard screws have a little picture of a keyboard next to them. Eventually, you will probably have to remove all the bottom screws. The keyboard will have screws at the top of it, so they are removed from the top as well as the bottom.
The case is held together with plastic tabs. Once all the screws are out, you can start in one corner and using a plastic or wooden flat utensil (actually a cuticle tool is good if it's plastic or wood) and gently pry the case apart. Then you can get to the fan. It's probably attached to a heat sink which cools the CPU, so you will need to use heat sink compound when putting it back together.
Feb 13, 2011 | Compaq (123482-001) Cooling Fan
How to remove the heater blower fan on 92 chevy 1500
Heater Core - REMOVAL & INSTALLATION
1991-92 R/V and 1991-98 C/K Series
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
  3. Remove the instrument panel glove compartment.
  4. Tag and unplug all electrical leads as necessary.
  5. Remove the center air distribution duct from the floor.
  6. If necessary, remove the ECM and mounting tray.
  7. Remove the hinge pillar trim panels.
  8. Remove the blower motor cover and then remove the motor.
  9. Remove the steering wheel and tilt back the instrument panel slightly.
  10. Remove the coolant overflow tank. Disengage the heater hoses at the core connections.
  11. Unfasten the attaching screws and nut and then remove the heater case.
  12. Remove the seven screws and lift off the heater case cover.
  13. Remove the fasteners and brackets that hold the heater core to the case and lift the core from the case.
To install:
  1. Install the heater core in the case.
  2. Install the heater case bottom plate. Make sure there is a good seal.
  3. Install the heater case into the truck. Tighten the 4 lower screws to 17 inch lbs. (2 Nm); the upper screw to 97 inch lbs. (11 Nm); and the nuts to 25 inch lbs. (2.8 Nm).
  4. Connect the heater hoses at the core tubes.
  5. Install the coolant overflow tank.
  6. Install the instrument panel and the steering wheel.
  7. Install the blower motor and cover.
  8. Install the trim panels and if removed, the ECM. Install the air distribution duct and reconnect all electrical leads.
  9. Install the glove compartment. Fill the cooling system and connect the battery cable.
Blower Motor - REMOVAL & INSTALLATION
1992-98 Models
(see Figure 4)
  2. Remove the right rear quarter panel trim.
  3. Disconnect the electrical lead at the fan.
  4. Remove the screws and if equipped, the cooling tube.
  5. If necessary, remove the fan retaining nut and lift out the blower fan.
  6. Remove the blower motor.
To install:
  1. Install the blower motor and then position the fan.
  2. Install the retaining nut and then tighten the mounting screws to 12 inch lbs. (2 Nm).
  3. If removed, install the cooling tube.
  4. Connect the electrical lead. Install the quarter panel trim cover.
  5. Connect the battery cable.
Fig. 4: Auxiliary heating and A/C system
Hope this helps (remember to rate this answer).
Nov 09, 2010 | 1992 Chevrolet C1500
Cooling fan burned up
Get a new fan motor and blade from GM or from an aftermarket supplier.
GM parts are usually better than the aftermarket ones, though for fit and functioin.
May also look into checking the relays and harness. If the terminals of the fan show they are getting current, then the motor will have to be replaced if not turning or obviously burnt.
Good luck on this repair.
Inspect/Replace
CAUTION
The fan that draws cool air across the radiator can be driven by either a belt or electricity. Rotating fans can be dangerous. Some are controlled by an automatic switch and can start unexpectedly. When working on electric fans, keep in mind that electric cooling fans should be disconnected when working around them.
When replacing a radiator fan motor, always refer to the vehicle's service manual. The following is a general guide for cooling fan replacement.
  • Disconnect the negative battery terminal at the battery. This is necessary on vehicles using electric fans, but some vehicles may require the relocation of the charging system components.
  • Drain the cooling system.
  • Loosen or remove the hose clamps, then remove the upper and lower hoses from the radiator.
  • Disconnect the transmission cooling lines and plug them off, if equipped.
  • Disconnect the electric fan motor connector, if equipped.
  • Remove the fasteners attaching the fan module to the radiator.
  • On some vehicles equipped with air conditioning systems, it may be necessary to discharge the system. This is the case if the radiator and condenser can not be separated in the vehicle.
  • Remove the upper radiator cross member or mounts.
  • Disconnect and plug the air conditioning lines at the condenser, if needed.
  • Remove the radiator and fan module as one unit if possible.
  • Separate the fan module from the radiator.
  • If required, separate the radiator from the condenser.
  • Remove the old fan module.
  • Install the new fan module onto the radiator.
  • Reattach the fasteners attaching the fan module to the radiator.
  • If equipped, connect the electric fan motor connector.
  • Reinstall the radiator.
  • Refill the cooling system.
Oct 29, 2010 | 1997 Chevrolet Cavalier
How to replace a blow fan motor on 2000 maxima
Exploded view of blower and cooling unit
Removing blower and cooling unit
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Discharge the A/C system.
  3. Disconnect or remove the following:
    • Negative battery cable.
    • Two refrigerant lines from the engine compartment
    NOTE Cap the A/C lines to prevent moisture from entering the system.
    • Glove box and mating trim
    • Thermal amp connector
    • Intake sensor connector
    • Fan control amp, blower motor connector
    • Blower motor and cooling unit
    • Separate the blower and cooling unit case, remove evaporator
    • Three bolts and motor from blower case
  4. To install, reverse removal procedure.
  5. Recharge A/C system.
Jan 04, 2010 | 2000 Nissan Maxima
Changing the water pump on 2000 Jeep Grand Cherokee V6
WATER PUMP
The water pump is bolted directly to the engine timing chain case/cover.
A gasket is used as a seal between the water pump and timing chain case/cover.
If water pump is replaced because of bearing/shaft damage, or leaking shaft seal, the mechanical cooling fan assembly should also be inspected. Inspect for fatigue cracks, loose blades, or loose rivets that could have resulted from excessive vibration. Replace fan if any of these conditions are found. Also check condition of the thermal viscous fan drive. Refer to Viscous Fan Drive in this group.
The water pump can be removed without discharging the air conditioning system (if equipped)
REMOVAL
Disconnect negative battery cable from battery.
Drain cooling system. Refer to Draining Cooling System in this group.
Do not waste reusable coolant. If solution is clean, drain coolant into a clean container for reuse.
The thermal viscous fan drive is attached (threaded) to the water pump hub shaft. Remove fan/viscous fan drive assembly from water pump by turning mounting nut counterclockwise as viewed from front. Threads on viscous fan drive are RIGHT HAND. Using special tool spanner wrench 6958 with adapter pins 8346 and a suitable fan wrench loosen the fan drive Viscous Fan and Fan Drive Do not attempt to remove fan/viscous fan drive assembly from vehicle at this time.
WARNING: CONSTANT TENSION HOSE CLAMPS ARE USED ON MOST COOLING SYSTEM HOSES. WHEN REMOVING OR INSTALLING, USE ONLY TOOLS DESIGNED FOR SERVICING THIS TYPE OF CLAMP, SUCH AS SPECIAL CLAMP TOOL (NUMBER 6094) SNAP-ON CLAMP TOOL (NUMBER HPC-20) MAY BE USED FOR LARGER CLAMPS. ALWAYS WEAR SAFETY GLASSES WHEN SERVICING CONSTANT TENSION CLAMPS.
CAUTION: A number or letter is stamped into the tongue of constant tension clamps. If replacement is necessary, use only an original equipment clamp with matching number or letter.
If water pump is being replaced, do not unbolt fan blade assembly from thermal viscous fan drive.
Remove two fan shroud-to-radiator nuts Fan Shroud Mounting Hardware Do not attempt to remove fan shroud at this time.
Remove fan shroud and fan blade/viscous fan drive assembly from vehicle as a complete unit.
After removing fan blade/viscous fan drive assembly, do not place thermal viscous fan drive in horizontal position. If stored horizontally, silicone fluid in viscous fan drive could drain into its bearing assembly and contaminate lubricant.
Remove accessory drive belt as follows: The drive belt is equipped with a spring loaded automatic belt tensioner. Relax tension from belt by rotating tensioner clockwise (as viewed from front) Automatic Belt Tensioner - When all belt tension has been relaxed, remove accessory drive belt.
Remove lower radiator hose clamp and remove lower hose at water pump.
Remove seven water pump mounting bolts and one stud bolt
CAUTION: Do not pry water pump at timing chain case/cover. The machined surfaces may be damaged resulting in leaks.
Remove water pump and gasket. Discard gasket.
INSTALLATION
Clean gasket mating surfaces.
Using a new gasket, position water pump and install mounting bolts as shown. Water Pump Installation - Tighten water pump mounting bolts to 54 N·m (40 ft. lbs.) torque.
Spin water pump to be sure that pump impeller does not rub against timing chain case/cover.
Connect radiator lower hose to water pump.
Relax tension from belt tensioner Automatic Belt Tensioner - Install drive belt
CAUTION: When installing the serpentine accessory drive belt, belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to Belt Routing for correct belt routing. Or, refer to the Belt Routing Label located in the engine compartment. The correct belt with correct length must be used.
Position fan shroud and fan blade/viscous fan drive assembly to vehicle as a complete unit.
Be sure the upper and lower portions of the fan shroud are firmly connected. All air must flow through the radiator.
Install two fan shroud-to-radiator nuts Fan Shroud Mounting Hardware
Be sure of at least 25 mm (1.0 inches) between tips of fan blades and fan shroud.
Install fan blade/viscous fan drive assembly to water pump shaft.
Fill cooling system. Refer to Refilling the Cooling System in this group.
Start and warm the engine. Check for leaks
Jan 10, 2009 | 2000 Jeep Grand Cherokee
Argus Roundabout 909 100 35mm Film Slide Rotating Carousel Tray Projector Mint Logo
Top Argus Video Cameras Experts
Are you an Argus Video Camera Expert? Answer questions, earn points and help others
