Question about Dishwashers
Fisher paykel dishwasher replace drain hose
I need to replace the drain hose my fisher paykel washing machine and can't work out how to take the old one off. Does anyone know how this is done?
My fisher paykel dishwasher will not drain water it washes a while and when spray water it stops and e5 comes on screen leaving water in machine
See if the water hose to the unit is kinked or otherwise restricted. If the water hose seem ok them you might have a defective water inlet electro valve. The video may help, be patient e5 is explained Fisher and Paykel Dishwasher Error Codes
Dec 14, 2016 | Fisher Washing Machines
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Replace dishwasher drain hose F&P DW60
The attached assembly document might be helpful. To access the drain hose at the dishwasher end your best bet is to pull the dishwasher out from under kitchen cabinet and lay it on the floor on its side. Make sure you disconnect the mains power and the hose connections first. The hose should be accessible from the bottom of dishwasher.
http://www.jordansmanuals.com/ServiceManuals/FP/Dishwasher/DW60CDW2/DW60CDW2.pdf
Mar 25, 2014 | Fisher and Paykel Dishwashers
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
GWL11 fails to drain
I had the same problem. After bailing out the water, I tipped the machine and saw a knee high panty hose caught up in the fan on the bottom. I removed that, checked to make sure the fan could spin freely, and viola! problem solved!
Jun 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher&Paykel DW60 drain pump is blocked.
Check the drain hoses by removing the dishdrawers from the machine and pulling on the hoses. I installed a Fisher Paykel DD602 about a month ago and the bottom drawer was not draining. I removed the drawer and freed up the drain hose and the machine worked fine.
Feb 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishwasher not draining well
Comment posted on Feb 07, 2009 there should be tabs on the sides of the drawers at the sliders near the front of the machine.
Feb 01, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Need to replace drain hose
there is a kit available to replace just the part from the back of the machine.normally the drain hose comes with the wiring loom big job.not sure what country you are in.kit is available in australia.
Nov 15, 2007 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
82 people viewed this question
Top Dishwashers Experts
