Remove the drain hose from my Fisher Paykel washing machine.
I need to replace the drain hose my fisher paykel washing machine and can't work out how to take the old one off. Does anyone know how this is done?
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
Fisher & Paykel GW611 Excellence does not pump water out. All lights are on and when it is suppose to pump, you can hear the noise, but no water coming out of the hose!
It sounds like the drain pump or the diverter valve is restricted. Check to make sure that the drain hose is clear then disconnect power and lay the machine's front on a padded surface to access the drain pump and the diverter valve at the bottom of the tub. Remove the pump's inlet and outlet hoses then check and clear from any debris that may prevent water from draining out. Check the impeller for any damage or restriction.
Check the diverter valve for the same condition as the pump described above. T
he diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure the valve is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
Jul 18, 2011 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel washing machine will not spin
Most likely something stuck in the pump, you need to look underneath to get to it, the pump turns anti clockwise to remove it.
Apr 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fault 52
Code 52 is a loss of water during recirculation cycle. Possibly due to a faulty divertor valve. Check to see if water is circulating back into bowl & no water escaping out of the drain hose. May also be caused by a faulty motor controller.
Jan 09, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Dec 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Need to replace drain hose
there is a kit available to replace just the part from the back of the machine.normally the drain hose comes with the wiring loom big job.not sure what country you are in.kit is available in australia.
Nov 15, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
