Question about NEC Lands Phones
I cannot establish a connection to my phone system
When I try to connect to my NEC UC desktop program I get the following message: Cannot establish a connection to the phone system. Please check network connection and IP settings.
Mark_Webber
  • 472 Answers
SOURCE: laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
Posted on May 15, 2008
SOURCE: Garmin ique 3600 hot sync issues
If your unit has a memory card installed, remove it and hot sync again. Follow reset prompts and everything should reappear. Good luck.
Posted on Sep 19, 2008
SOURCE: NEC DTerm80 phone
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Posted on Oct 28, 2008
  • 149 Answers
SOURCE: Connect/Program Headset
Sure you can do it. as long as the headset has a plug for the handset your fine. Plug it in and you will have to pick up and hang up the handset as needed. The headset key eliminates you having to pick up and hang up the handset to answer with the headset.
Posted on Nov 18, 2008
SOURCE: IP Phone available for IP office?
If your IP Office is Rel 4.2 or higher, You can purchase a license that will allow you to load a vpn script into the phone. Once you set up your VPN router at corporate, the phone gets plugged into any open internet connection and syncs up with the VPN router and makes a tunnel which then will connect with the phone system giving you a remote IP phone extension of that system.
For the PC, just load client software on it, and it works the same.
Since the tunnel is directly from the device (phone or PC), your home network will not be apart of the office network.
Posted on Mar 12, 2009
HOW DO YOU CHANGE THE HOLD MUSIC ON A NEC PHONE SYSTEM
It depends on the system type. some are built in and done through programming. others are connected viz an rca jack on side of the cpu cabinet. post what type of system you have.
Aug 12, 2014 | NEC Lands Phones
Garmin hotsync issue
Hey uninstall the program, download the newest one available and try again.
Sep 08, 2008 | Garmin iQue 3600 GPS Receiver
IPAQ HX4700 won't sync with desk top
Hello, Please try the following steps. They could help with your problem. First open this link to hp's download page for your PDA. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?&lang=en&cc=us&pnameOID=420535&taskId=135&prodTypeId=215348&prodSeriesId=420534&lang=en&cc=us Then select your pda's operating system (windows mobile 2003se or windows mobile 5). then from the following page select the ROM update and download it. Try to master reset the pda (you may find informations about this in the user manual). After you reset the device, don't tap anything on the screen (don't follow the welcome wizard or anything it asks you to do). Just connect the usb cable to the computer. Activesync may try to connect to the pda, may fail or things like this. It doesn't matter what does it do as long as it does something. Now open the ROM file you downloaded and press "next" untill the process begins. If the setup asks you to reset the device or things similar, don't do it. Just continue with the setup and "tell" the program you already done that. Make sure your battery is charged before doing this. Also make sure the pda and the computer are left alone these 10 minutes (that's how long it takes to do the ROM update). If the ROM update fail, please post a comment and give me the error message and code. We will take it from there. Also please inform me what version of windows are you using and eventually an email adress for me to send various service programs required for the next stage (if the rom update fails to work). Good luck, Bogdan
Sep 25, 2007 | HP iPAQ HX4700 Pocket PC
What is this please help please
Have you read the last line of that message. Perhaps that would be a good place to start
Jul 16, 2014 | Nintendo Video Game Consoles & Games
How do I connect my Matrix m1 mobile phone to the internet?
How to Use the Pantech Matrix for the Internet1.Press the "Menu" key on your Pantech Matrix and click "Settings.
2.Click "Connections" and highlight "Modem Link." Press the "OK" key. Turn the modem link settings to "Inactive." Press the "End" key to exit to the phone's standby screen. 3.Download and install ActiveSync on your computer if the operating system is Windows XP. If you have a later version, download and install Windows Mobile Device Center. Follow the on-screen prompts to properly set up the program. 4. Press the "Menu" key on the Matrix and click "Settings." Scroll down to "Connection" and press the "OK" key. Click "USB" to "PC." 5. Open ActiveSync or Windows Mobile Device Center. Click "Device Settings." Click "Internet Sharing" under the "Programs" tab of the program. 6.Select "USB" from the drop-down menu under "PC Connection." Select "AT&T" from the "Network Connection" drop-down menu. 7.Click "Connect" and connect the Matrix to the computer using a USB cable. A status message of "Connected" will appear in the program's window when the connection is established.
Jul 21, 2011 | Pantech Matrix Cell Phone
A connection with server cannot be established message I keep getting. I can see my router fine but cant connect.
This problem is because there is some misconfigurations that you might have done on the ip address part or either you have added a static ip address which is not getting along with either the DHCP address.
So just check that and try. or else remove it then put it back then try.
May 27, 2009 | Proxim ORiNOCO (8480-WD) 802.11a,...
Unable to connnect wirelessly thru gprs phone.
You need to connect first one system with the phone. have the proper software of the phone installed on the system and your system should detect it as a modem. you may need to contact your network provider for assistance. Once you have establish a connection on the first sytem and it culd browse, that is the time that you need to create an ad hoc under create a new connection. once you have established an ad hoc, let your other system detect it wirelessly and try to connect to it.
By the way GPRS is similar to dial up so if you have 2 systems online it is just like splitting your 56k connection speed and it could give you no browse at times.
Hope this helps...
Jul 24, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
Error message: "Unable to establish a secure connection"?
This error can occurs because the VeriSign Certificate Authority (CA) has changed the hashing algorithm that is used for new Secure Sockets Layer (SSL) server certificates from Message Digest 5 (MD-5) to Secure Hash Algorithm 1 (SHA1). A supported fix is now available from Microsoft for Windows CE 2.11 and Pocket Explorer 3.0 this fix can be found at: http://www.microsoft.com/mobile/handheldpc/downloads/128bit.asp Note: After you have downloaded and installed the fix, be sure to soft reset the device.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Lands Phones Logo
22 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
