Question about Taylor Professional 330 Lb Analog Bathroom Weight Scale
Think a spring sprung
Heard a funny noise does not weigh properly neddle bounces around alot
Why dose my my car make banging noises going around roundabout and bends and
sounds like a suspension problem as weight being transfered around the suspension so get the springs and shock absorbers checked , easy check for shock absorbers, bounce car on each corner ,if car stops smoothly then ok but if continues to bounce after you've stopped bouncing it then the shocker is worn , get the springs tested at a garage as will need specific equipment etc
May 01, 2014 | Mazda 626 Cars & Trucks
Funny noise coming from the air filter
probably bad ice maker
http://www.shopjimmy.com/
Sep 06, 2012 | KitchenAid Refrigerators
Bosch WFL 2462 is out of balance during spin cycle
I would think it unlikely that the springs have failed unless they are fractured.It's more likely to be the shock absorber or absorbers. Depress the drum and watch how it settles, if it continues to 'bounce' around its the absorber(s), if it settles after one bounce then it's something else.
Make sure it's levelled ok
regards
w
Nov 02, 2011 | Bosch Classixx WFL 2462 Front Load Washer
My xbox 360 is making clicking noises, vibrates alot, and is extreamly loude while running, i think its the fan in it but im not sure, so what should i do?
Hi Charles
There are several reasons your console is noise , First remove your game and
listen and see if the noise is reduced also the vibration should stop too.
I have seen or heard rather this before . The cause was a the drive spindle
hub some how got skew so the disk wobbled as it was spinning.
The fix was simply to replace the hub/spindel motor .
The rattling sound may be from the tilt switch or pieces of plastic
bouncing around . you will have to open your console to remove the
the small chunks of plastic + blowing it out will help cooling also.
The fan should not make that much noise . If it seems to be loud
then you may need to replace the heat sink compound on the G.P.U.
and the C.P.U.
if you have any questions feel free to ask.
Rob
Mar 31, 2011 | Microsoft Xbox 360 Console
On start up of spin cycle noise can be heard intermittently, sounds like a loose belt bouncing around, only heard on power up intervals of spin cycle
try to locate your drive belt for the agitator. if your drive belt doesnt need to be replaced it may be the gearbox
Jan 29, 2011 | Washing Machines
Frontend bottoms out
Mike, extend the travel in the front springs might help but I'd say you may have to replace the front springs. If she has bottomed out alot, also check the bump stops for damage.
Aug 11, 2010 | 1989 Jeep Cherokee
Rear noise vw passat 1996 tdi estate
change anti roll bar bushes.Allso check coil springs are not brocken.
Jul 04, 2009 | 1996 Volkswagen Passat
When drum spins it makes alot of noise.
Check the main bearing and the pulley to make sure that they are both working properly if the bearing is bad it will make the drum bounce all over, if the pulley is bent it will make kind of a grinding noise along with things jumping everywhere
Feb 11, 2009 | Frigidaire FTF2140ES King Size Front-Load...
Bowl off track
Spring missing or skid plate out of place. if the basket has excess movement separate of the tub or agitator then the hub nut is loose or tub rusted out.
Jan 19, 2009 | Whirlpool Inglis IP4400 Washer
Taylor Professional 330 Lb Analog Bathroom Weight Scale Logo
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
