Question about Cobra Electronics - Others
Need manual for Cobra CPI 1575 3000 Watt 12 Volt DC to 120 Volt AC Power Inverter
miket756
  • 2702 Answers
SOURCE: Can A cobra inverter be plugged in to 115AC for DC 12volt output
in a word no!,,,,it cannot and you may blow it up if you hook it up to the 115ac volt supply,,,in side it there is a switch mode power transistor,,that bumps up the 12 volts to 115 volts it only works the one way,,that is 12 volts dc in and 115 volts ac out,,,,
Posted on Feb 22, 2010
Testimonial: "Thank you for the info and keeping me from blowing up"
al_kupchella
  • 843 Answers
SOURCE: 200/400 watt Powerline Dc to AC Inverter blows fuses
If the inverter is blowing the fuse immediately upon plugging in the inverter (before you even plug something into the inverter) you most likely have a short in the 12V power cord. If you have an Ohm meter, you should be able to check the resistance across the two contacts on the 12V plug of the power cord. Wiggle it around some. If you get a very low reading, and especially if it's intermittent, you have a bad cord, which should be pretty easy and cheap to replace. My experience with these cords has been that their quality is pretty poor.
If that is the problem, maybe you can cannibalize a cord from an old CB radio, but here's a fairly heavy duty one on Amazon (they don't give an amp rating though) http://www.amazon.com/Truckspec-TSPSCBH-2CP-12-Volt-Platinum-Replacement/dp/B001JT5QF0
Posted on Feb 23, 2010
Testimonial: "Al, the idea on the Powerline appears to be the correct solution. The R was very low as you predicted. I'll change out the powercord. Thanks !"
  • 4 Answers
SOURCE: power inverter
There are 8 40A fuses inside this unit. In the following pics you will see a bank of 4 and another bank with 3 of the 4 removed. I'm currently working on mine as it will cost me more to ship and have Cobra repair than I paid for the unit ($133 to repair). Good luck with your problem
Posted on Aug 24, 2010
  • 20 Answers
SOURCE: 175 watt 350 peak inverter 12v dc to 110 ac need
Hi
15/16 amp would be recommended.
You could to try a 20 amp, but you will risk overheating and the possible failure of the vehicle circuit fuse.
Regards
Posted on Jan 30, 2011
caroldon
  • 17130 Answers
SOURCE: cyberpower 1000 watt 12 volt
When the wattage of an invertor is specified it is meant for the power load but with a gradual CURRENT drain. If you load with modest loads of lighting , fan or other low wattage device it will work without tripping off. In this case your microwave when loaded will initially start up with a large surge current requirement thereby shutting off the invertor as it detects overload. So the safe limit to operate a microwave is to have an invertor above 2000 watts . If the input supply is 24 volts , then it will be more powerful.
Also try with a low wattage/heating setting on the microwave, tighten the battery terminals of the battery . Sometimes it might start but can also damage the invertor. failure of the driver MOSFETS.
Posted on Jul 12, 2011
Need Help with burned resistors value. Please.
have you repaired the component that burned these resistors out? if not then you cannot replace them as they will just cook again.
Nov 06, 2015 | Cobra CPI 1575 1500 Watt 12 Volt DC to 120...
Cobra inverter
should probably connect it straight to your battery or you are trying to use something that requires too much power.
Sep 04, 2014 | Cobra 12 Volt 2500 Watt Power Inverter...
88 ac volts at receptical
Sounds like the transformer is done. Have a big switch on the DC side, to turn it off when not in use. Being on all the time burns it out.
Nov 25, 2013 | Cobra CPI 1000 DC to AC Power Inverter
How do I remove olp message
Its an inverter DC to AC---what since I do not understand the described problem is the unit doing or not doing?
Dec 04, 2012 | Cobra Cpi 2575 5000-watt, 12-volt Dc To...
My 12 V 400 watt inverter worked fine until recently, when in would no longer power anything. I checked the AC output voltage and am gettting only 25 volts, rather than the 110-120 volt range. Any...
My guess would be the power oscillator mosfets. Was the 25V AC or DC? If there is no AC and the output is DC then the chances are very good that one of the switching mosfets that produce the AC is shot. These are usually set up in an H-Bridge configuration and both the neutral and hot leads alternately get switched between high voltage DC and ground, producing a modified sine wave output. For the cost of one of these inverters, it might be cheaper to just buy a new one and recycle the old.
Jan 19, 2018 | Vector 400 Watt Power Inverter #VEC024
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
Feb 22, 2010 | Cobra 2500w Power Inverter
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
Electronics - Others Logo
Top Cobra Electronics - Others Experts
Gil Shultz
cwradio73
Bill Boyd
Are you a Cobra Electronics - Other Expert? Answer questions, earn points and help others
