Question about Sure Lites All-Pro Dusk-to-Dawn Small Single-Head LED Security Floodlight With Photocontrol, Energy Star Rated - Bronze
Lights goes on and off - Sure Lites All-Pro Dusk-to-Dawn Small Single-Head LED Security Floodlight With Photocontrol, Energy Star Rated - Bronze
Connecting lighting correctly
Don't know what you're working with.
AC household electricity?
Common (White) wire goes to all three lights. Goes to silver colored screw.
Hot (Black) wire goes to switch, then all three lights.
ALWAYS put the switch in the hot wire. Not the Common.
Reason?
Let's say you are changing a light bulb.
Your feet are on the floor. You are then considered to be Grounded.
You have the light switch off. You go to remove the light bulb, slip, and a finger goes in the socket.
Result?
You get shocked.
Hot (Black) wire has the switch. This time of you slip, and a finger goes in the light bulb socket; you won't be shocked.
The power is turned off at the switch.
Common wire comes from source. (Service Panel/'Breaker Box'), and goes to the lights.
Hot (Black) wire comes from source, and goes to light switch.
Then to the first light, second light, and third light.
Is there a 3-way switch involved?
Walk in one end of the room, turn the light on, walk to the other end of the room, and turn it off?
Post back in a Comment as to the exact query.
Regards,
joecoolvette
Jan 26, 2013 | Computers & Internet
Service engine light goes on and off. diagnosed
just remove the battery cable for about 5min then put it back. that should reset the check engine light.
Jan 17, 2010 | 2000 GMC Jimmy
Power light comes on and then goes off.
power light comes on and then goes off
Dec 08, 2009 | Acer Aspire 3680 Laptop
Red light on,press power on grenn light goes on
Have the main power supply checked out first, you only have standby 5v power supply working right now.
Oct 30, 2009 | ViewSonic N3752w 37 in. LCD TV
Chevy cargo light cycles on and off...
Look for grounding problems, that is the most common issue with multiple, seemingly unrelated symptoms.
Sep 25, 2009 | 2008 Chevrolet Silverado 1500 2WD
Little yellow warning light goes on. All bulbs
you most likely have a wrong brake light bulb. if the bulb is a different wattage it will still work but the bulb warning light will still illuminate.
Sep 25, 2009 | 2005 Lexus SC300
Sure Lites All-Pro Dusk-to-Dawn Small Single-Head LED Security Floodlight With Photocontrol, Energy Star Rated - Bronze Logo
63 people viewed this question
Top Sure Lites Home Security Experts
Lawrence Oravetz
Are you a Sure Lites Home Security Expert? Answer questions, earn points and help others
