Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Odc325 coffee maker works fine but does not maintain heat on brewed coffee. can this heating element in base be replaced.
Re: odc325
I have no solution, except to say the same thing happened to me in October 2007. I took the coffeemaker back to the retailer; they replaced it & that one worked fine until July 2008, when the water reservoir started leaking.
Posted on Aug 14, 2008
Re: odc325 - Black & Decker SpaceMaker ODC325 Coffee Maker Coffee Makers & Espresso Machines
Buy a used coffeemaker at ebay
Posted on Jun 26, 2008
  • 30 Answers
Re: odc325
I haven't been able to find the base heating element for sale anymore. Best I can suggest is finding one on ebay that still has a working base heater but the water heater no longer works.
0 characters
3 Points
Brews good hot coffee but warming plate has stopped heating! Are replacement elements readily available or could it be a fuse...??
The DCC-1200 has only one element, that both heats the water for brewing and keeps the carafe warm. If you're brewing coffee then the element is fine and the suspect part is the Thermistor. Another forum suggested this was a Vishnay NTCLG100E22245B, available from DigiKey (their part # BC2467), connected to the control board with thin yellow wires. The same forum suggested that this thermistor should test at 220K ohms at room temperature, dropping to 20K at about 220F.
Nov 17, 2015 | Cuisinart DCC-1200 Coffee Maker
Coffee maker
This model of coffee maker has an adjustable heating element beneath the carafe - ensure the temperature setting for the carafe is high enough to keep the coffee hot.
If the coffee is not brewing hot, the initial heating element/coil may have failed. Removal of the heating element is somewhat problematic and will require disassembly of the water container and base of the coffeemaker, and will likely need to replace the heating coil contained in a plastic sheath. Ensure you take a look at:
for further detail.
Apr 07, 2014 | Cuisinart Dcc-2600 14-Cup Coffee Maker
Water leaks out between coffee brew basket and carafe.
If you are noticing the water that is leaking at the base, I was having the same problem. If you can specifically see that the leak is coming from between the basket and carafe - then you may have a different problem. My problem appears to be that the heating element is shot - it leaks when you start the brewing cycle. I found this out by taking off the bottom and raising up the coffee maker and puting it on a mirror to view what was going on. As soon as the brewing starts and the system is under pressure, water starts forming on the metal tubing part of the heating element. I suppose it's possible that water is leaking down from the tubes, but it looks like it is getting forced out of the metal, so there must be small holes, caused by corrosion. I will check further but I can't find a replacement heating element online so I may have to purchase a new coffee maker.
Apr 21, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
The coffee pot won't turn on anymore
burnt thermal fuse or heater does heater work under coffee pot? :)
Jul 03, 2009 | DeLonghi DCM485 Coffee Maker
Odc 400 dont work
Need a few more details. When it's plugged in: I assume it doesn't brew; Does the clock work? Does the base element warm up when the switch is moved to on?
Jun 29, 2009 | Black & Decker SpaceMaker ODC325 Coffee...
Wont heat or brew!!
Make sure the coffee maker is unplugged there's 120 lethal volts inside when plugged in!
This unit has a replacable thermal fuse. It's a "Microtemp" Thermal Cutoff Fuse G4A00. You can buy five on eBay for $2.70. There are two on this unit and they are in the base concealed inside a 3" white mesh that runs alongside the heater. You will need a security fladebladed screwdriver that you can make by filing a notch in the center of a regular screwdriver.
Jun 28, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
Heating Element Shuts Off Very Early
Reset the timer for shutting off the hot plate, instructions are in the user manual.
Jan 31, 2009 | Cuisinart DGB-300 Coffee Maker
Hamilton Beach Brew Station
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Filter basket
You can find ODC325s on ebay just for parts since the heating element is shot. I don't believe those parts are for sale anymore.
Jul 21, 2007 | Black & Decker SpaceMaker ODC325 Coffee...
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
334 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
Jack Reed
Level 1 Expert
Mike Cairns
Mike Cairns
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
