Question about Ruud Heating & Cooling
Furnace blows cold air
Blows hot then cold, won't shut off
    Genius:
  • Ruud Master
  • 1,363 Answers
Sounds like blower relay stuck.
Posted on Aug 11, 2015
Ice maker
  • 8 Answers
SOURCE: ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Posted on Mar 27, 2008
SOURCE: comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
Posted on Jun 08, 2008
  • 108 Answers
SOURCE: amana furnace
This is no doubt due to failure of the "hot surface ignitor". This device lights the main burners for your furnace, and they fail a lot. I strongly recommend the replacement should be done by a technician.
Ray
Posted on Oct 25, 2008
Accurate Joe
  • 61 Answers
SOURCE: Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Posted on Nov 29, 2008
diths_kri
  • 67 Answers
SOURCE: furnace blowing cold air
THERMO
Posted on Jan 07, 2009
Furnace blowing cold air
Turn power off & on again. Watch to see if it cycles...it could be the hot surface igniter if you don't see it turn bright orange. If it goes straight to blowing cold air, then normally it is a limit switch open- mostly manual reset - thermal disc-located around flame rollout.
Dec 20, 2013 | Ruud RGTM10ERBJS 100K BTU 95%...
My goodman furnace lights and burners comes on but blows cold air.
To much question.i want to know where is mag box now.
Nov 28, 2013 | Heating & Cooling
Ruud furnace troubleshooting
check that elements are intact and getting voltage
Nov 14, 2013 | Heating & Cooling
94 Buick Roadmaster AC fan blowing hot and won't shut off
If you have climate control it could be the main processor. Something could be shorting the blower relay to keep it on. You would also need to check and see if the system is still full of freon.
Jul 06, 2013 | Cars & Trucks
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
House heater does not blow hot all the time. the furnace kicks on and then shuts of and then the blower just blows cold air. the furnace tries to kick on three times but shuts off, sometimes it works just...
When it blows cold air, there should be an error code blinking on the LED light located on the PC board. Look through a small viewing port in the front panel, then remove the front panel and on the reverse side there should be a diagnostic code chart to help you figure what is wrong.
Mar 15, 2011 | Coleman Heating & Cooling
Nov 29, 2008 | Heating & Cooling
Heating & Cooling Logo
65 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
