Question about Naxa "NT-1506 16"" Widescreen HD LED Television, Built-In Digital TV Tuner"
Naxa Nt-1506 comcast remote code - Naxa "NT-1506 16"" Widescreen HD LED Television, Built-In Digital TV Tuner"
REMOTE CODES FOR naxa nt-1506
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. .
Dec 19, 2016 | Televison & Video
REMOTE CODES FOR NAXA NT-1506 TV
@#!&< *!%#< #)$) Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
Programming Notes
Search the site by type in the "brand name" of your device; that you want set-up code, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
How do i program twc ur5u-8780l remote to turn off/on naxa nt-1506 television
Programming Notes
Naxa ND-856 DVD player connect to universal control
Use code search on your universal remote to find something that manages some or all Naxa functions. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Dec 07, 2016 | Universal Televison & Video
I have no remote for the tv,so i need the code for a naxa 15.6inch led tv. Ill enter it into my direct-tvs remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order.Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window.It will help you to find the document easily.
Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Sep 17, 2015 | Naxa 15.6 Inch NT-1506 12 Volt AC/DC...
How do I program naxa nt 52digital converter with a universal remote
You may not be able to. Digital converters have unique control codes to prevent interference with TV remotes.
Apr 29, 2014 | Televison & Video
Set up
About which setup you are talking about. Universal remote control setup. If so, try these links.
May 20, 2013 | Televison & Video
Universal Remote Control Numbers needed for NAXA TV Model NT-1506
0483,0291,0382,0957,0000. Check these codes. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 18, 2013 | Naxa Electronics Televison & Video
Universal remote
call for a factory remote at1-800-736-6837
Nov 01, 2007 | Naxa Electronics Naxa NX-572 7" TFT LCD...
Naxa "NT-1506 16"" Widescreen HD LED Television, Built-In Digital TV Tuner" Logo
37 people viewed this question
Top Naxa Televison & Video Experts
Randy Handy
Trippy Tripp
Are you a Naxa Televison and Video Expert? Answer questions, earn points and help others
