Question about Vehicle Parts & Accessories
How to program a ezsdei474v to a viper 130xv - Vehicle Parts & Accessories
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
You're going to have to call the manufacturer to get those answers.
Posted on Feb 08, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How do I program my viper replacement transmitter for my car.
Dear Marta,
Here is a hands on to watch and program as you go. Follow to the link. How To program DEI Viper Python Avital Sidewinder Valet Hornet Alarm...
Here is another look. 1f Responder LE Remote Pairing
For your direct contact to Viper follow this link for any question. Viper Support
Fare. Well.
Dec 12, 2014 | Viper Vehicle Parts & Accessories
How to program a ezsdei474 remote to a viper 130xv
Open door, turn on ignition. Press and release valet switch then, press and hold valet switch. Press lock button on remote. Release valet switch, turn off ignition. Test.
Feb 08, 2014 | 473v Viper Remote Case Three Button
Program remote
get in vehicle turn key on with new key fob in car, let run for 20 or so then turn off . hit the unlock button it should be programmed but not promising anything lol
Sep 30, 2013 | VIPER 7141V VIPER 4BUTTON REMOTE 7141V
How to take my viper remoter off vabration. a where can i find the manual for the viper remoter
To enter programming mode Press the Program button on the back of the remote or hold the four remote control buttons on the front of the remote simultaneously until one long beep is heard. Programming Mode has now been entered.
Beep/Vibrate Mode Within five seconds of entering Programming Mode, press Lock. The remote control will beep once for on, twice for off. The vibrate icon (13) will also turn on/off with each press.
Here's the owners manual for that system: http://www.directeddealers.com/manuals/og/viper/G5301V_05-06post.pdf
remote programming starts on page 15.
Mar 25, 2011 | 7701V Responder SST Remote
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
I need a instalation guide for a viper130xv remote starter
I can email it to you. My email address is solomonsfinest@aol.com. Put Viper 130XV in the subject line
Sep 15, 2010 | Remote Start System
My viper remote, no matter what button I push on it just beeps and an icon that looks like a antennae flashes but nothing happens.
Try this first, unplug the 2-way antenna on your windshield. Let it sit for at least a few minutes. Try recoding the remotes after you replug the antenna back in. This is an issue i have seen on some of the Viper units. Usually they never have issues, but here and there they need reset.
Aug 21, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a viper starter and car alarm with 2 controlls and one got stolen what should I do
The Viper alarms will accept (if I remember correctly), 4 codes at one time. That is, 4 individual remotes, or two remotes two times, or one remote 4 times. So, if you program your remote 4 times, it will essentially remove any previously programmed remotes. Another option, and you'll have to check with your dealer, but I think there is a way to delete ALL remotes, and then program your remaining remote one time, and again, all previously programmed remotes are now removed from memory. This was done by the manufacturer just for such events.
May 17, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
