Kinetic Loud Speaker KA-4260
Can i use a Kinetic Loud Speaker KA-4260 for my onkyo TX NR414?
    Problem Solver:
  • 8 Answers
Kinetic speakers are generally 8 ohm, so they should work fine with the Onkyo.Your amp has a rating of 80 watts per channel, but I'm not sure of the power handling of the speakers.
Posted on Feb 14, 2014
3 Suggested Answers
SOURCE: kinetic ka-5100 manual?
I have KA- 5100 5.1 ch home theater wht amplifier ineed to conet
Posted on Aug 14, 2011
sunrisenohch
  • 95 Answers
SOURCE: I need help with my Kinetic KA-5100 home theater ,
Look like here you can download user manual.
http://www.imarkswebs.com/bk/kinetic+speakers+ka+5100+operational+manual+pdf/
Posted on Oct 06, 2013
Dont know where to find the return authorization # for my package im returning
Hi Russell, the return authorization will typically start with an R, if you email me the units serial number I can check our system and advise, please email me at askOnkyo@us.onkyo.com, Thanks, JT
Dec 20, 2015 | Onkyo TX-NR414
Intermittent sound
Try a digital coax or optical for audio and see if that helps, you will still get all the benefits of HDMI video but perhaps no audio issue,ensure your kit is running up to date firmware. If that don't help play with the connections try a different HDMI cable, different VIDEO source or try the connections with a different AMP .
Hope it helps... :)
Jan 21, 2014 | Onkyo TX-NR414
Onkyo TX-8410, speaker selector B not operating. When I have the speaker selector on A&B or just B, the B speakers do not operate. If I switch the wires from the same speakers to the A channel, the...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-8410-Receivers-manual/id/365ci162/t/2/
Individual speaker leads are not fused. It's possible the switch is defective. Does it light the speaker B indicator? If not, I'd suspect the switch.
If it DOES light the Speaker B indicator maybe there's an open circuit going to the Speaker B terminals. Or its common ground for that speaker pair alone is open.
May 17, 2011 | Onkyo TX-8410 Receiver
Trips and switches off
Hello Fixya customer,
Thank you for your question.
The best way to fully isolate the fault is to disconnect all the speaker wires, and verify that there are no strands of wire shorting between the speaker terminals on the rear of the unit.
Turn the volume all the way down, full CCW, and if it goes into shut down with the STBY light blinking then there is a fault in one of the amplifier's.
Thank you for using Fixya, and if I can be of further assistance please ask.
May 01, 2010 | Onkyo TX-SR706 Receiver
I have an Onkyo TX-605AV receiver that will goturn off andgo into standby mode with loud sounds, when the volume is turned up usually over 60. I hooked the speaker wiresinto the banana clips for the...
over heating your amp with a problem and its going into the protect mode... better stop before it dies for good...$$$ to fix....speakers mismatch or wrong ohm rating for starters bad speaker, bad xover...
Dec 05, 2009 | Onkyo TX-SR605 Receiver
VERY LOW VOLUME FROM SORROUND SPEEKERs
some surround sounds do not put out loud sounds except from the front speakers only. Try using different inputs to see if it makes a difference.
Jun 17, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SV 727 PROTECT mode
Generally, this happens when there's a loose connection somewhere, either internally, or with the connections. It usually happens when the volume's too loud, and it tries to protect itself.
I'd suggest you unplug everything from it, check all the speaker wires, and then try turning it on, without any devices connected to it.
If it works, turn it off, and reconnect devices, one by one. That should fix it.
If not, it's likely that there's a loose solder inside, and it needs to be sent out for service.
Mar 19, 2009 | Audio Players & Recorders
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
208 people viewed this question
 Grubhead
Grubhead
