Washer won't advance, have already replaced the timer. We can manually advance it but that was the whole reason for replacing the part. Lid switch is fine, will fill with proper water level, will spin and rise, but won't advance through agitate cycle. Thanks
Hi iv acidently washed a poise pad in the washing machine ,,the pad broke open and a gel like substance is all through clothes is this toxic,,is it silicone?? what if we wear cloths will it be absorb in blood system if we wear them im stressed as gel filled whole washing machine,,and dont know if clothes are safe to wear,,i cant find any info on wether poise gel in pads is dangerous plz help arrgghh
Posted on Feb 08, 2014
4 Suggested Answers
  • 686 Answers
SOURCE: LSR9434PQ3 Washer stops in cycle
weak capacitor. Bolts onto motor
Posted on Apr 06, 2009
  • 7 Answers
SOURCE: Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Posted on Aug 24, 2009
Testimonial: " "
  • 4044 Answers
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
Posted on Oct 30, 2009
Maytag top load washing machine repair
It sounds like your Maytag (now owned by Whirlpool) Actuator needs to be replaced. Last year our Maytag Centennial top loading washer Model MVWC300XW0 would not drain all the water and cloths would be soaking still. Doing some online research, I came across some very helpful video regarding replacing your Actuator.
The only thing I would recommend to future installers is get your Technician Manual located just inside the case (front panel) first of your Washer. The Technician Manual is taped inside your washer in a plastic bag. Once you replace this Actuator part, I recommend that you run the Calibration cycle on your washer. It is needed anytime you replace a motor, motherboard or pump.
Here are two videos describing how to change/replace the Actuator but these videos are basically for the MVWC300XW0 model. I'm sure if you search for your model, there will be other videos as well.
Two videos on how to replace your Actuator:
1: https://www.youtube.com/watch?v=YVjTY-Hj4jw
2: https://www.youtube.com/watch?v=yTHryoT78pA (This is video that I viewed the most)
Best of Luck!
Jun 05, 2016 | Maytag Washing Machines
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
I have a Frigidaire FTF530FS washer with a problem. The Timer gets stuck in between the drain and the spin cycle. It occurs when the timer dial is about 3 o'clock. I replaced the drain pump, the door...
Good Morning kvojik, thanks for your post!
From my understanding your Frigidaire front load washer is getting stuck between the drain and spin cycle. I noticed that you have replaced many components within your washer and continue to experience this issue. I would not advise to manually advance any part of the washer because this could cause issues within your washer. It could be a potential issue with the motor. At this point you may want to reach out to a technician for proper diagnosis and repair. This will help you to avoid any further part purchases. -Matt
Feb 21, 2015 | Frigidaire FTF530FS Front Load Washer
Maytag washer MAH4000AWW timer will not advance. Washer will operate if I manually advance timer. Have changed timer, followed Drive System diagnostic test, the wax motor and control board were replaced a...
there is a motor inside the timer that turns the knob. the problem must be the replacement timer. was it a brand new timer from maytag or a 2nd hand? also double check your timer is connected correctly.
Nov 08, 2013 | Maytag Washing Machines
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Whirlpool top load washer won't advance through cycles
A small motor that rotates the timer has gone bad. Common practice is to replace the timer. Usually a mechanical timer of this type is less expensive than a computerized timer.
Mar 14, 2012 | Whirlpool LSB6300PW Top Load Washer
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
Washer will not move to next cycle; has to be done manually
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. Hope this helped.
Jul 16, 2009 | Washing Machines
Washer sticks in spin mode during most loads
hi there,
the timer is actually a mechanical switch. sounds like you have answered your own problem. it's time to replace the timer.
Oct 01, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
