Question about Jenn-Air Kitchen Ranges
Jjw8130 gaz cook tap - Jenn-Air Kitchen Ranges
How to charge ac after changing compressor
You need to do a good vacuum ( about 500 micron) problably this car work with R12 refrigerant. This gaz is not legal now you have to find a remplacement. With the new gaz , a chart tell you how percent gaz of the new one you have to insert in system. If it's work with R134 , you have to put exactly the amont of gaz write on the plate on the hood. You need lot of speciality tool, may be it much better ask to somebody know her job. Mario
Apr 10, 2014 | Jaguar 1998 XJ8 Base
ABS, BATTERY,GAZ LIGHTS WENT ON
no I am not there.. you need to put gas in.. charge the battery and try to start the car..after it charges a few hours..
Jan 02, 2014 | 1999 Chevrolet Venture
Frozen gas line
that mean you have water in the gaz tank if its condensation no problem 1 bottle of gaz line antifreeze your good put it in wait like 10 minute should start if the bottle doesnt do the trick that meam water infiltration your car not that old check for bad gaz last time you fill up thank you for your post .pierre
Feb 27, 2011 | 2005 Nissan Sentra
Where is the fuel filter located on a 2003 envoy SLT
with the injection the gaz filter is in the gaz tang with the gaz pump.
Nov 14, 2010 | 2003 GMC Envoy
Installed new fuel pump car still won;t start
Check Filter inside Carb.. Also Under Beside the Gaz Tank ..Check unplug Gaz line beside Carb and start ..See if gaz came.. if yes
check filter inside Carb....Check wile pressing gaz pedal see if gaz spay . Make Shure The Primer Work Find.. Then Chek For Vaccum lost Vaccum Are Important For System Performance.. Some Logic Board work with Vaccum Exemple Boddy Trothle.. Electric Choke... Cruse Control Idle Control and Distributor Advance..
Good Luck
Oct 06, 2010 | Honda Accord Cars & Trucks
The sealed system looses gaz and refregirator is not cold
Most likley the part you need is the evaperator. and geting one if the company is no loger in operatoin will be like hitting the lottery. If you want the part, your best bet will be E-bay.
But I have a posible solution that you could try and I have had a 50% sucess rate with and its a sealer Part number 947kit called ((( ACR super seal )))
You can look it up and read on it. Some tech's don't like it and some do.
There is no garentee that this will work for you but is worth trying if you have no other option.
you will half to put a line tap on and put a vaccume on the system befor installing the sealer then the freon.
This is a use at your own risk. cost is $30.00 to $60.00 + Line tap and freon
will work with almost all freon.
Jan 11, 2010 | Danby DFF1708W Refrigerator
While fueling pump stops and says 3/4 while almost m.t
Do not push the nozzle completely in the filler tube. it may be triggering a sensor because a lack of air flow with the gas.
Jul 22, 2009 | 2004 Pontiac Grand Prix
Toyota corolla 98 1.6L unleaded does not start
the alternator ground must be loose... try tracing the both negative and positive... tighten the connection... if problem persists try replacing the alternator
Jul 19, 2009 | 1998 Toyota Corolla
After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Apr 14, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Smells like rotten eggs
This is a normal condition for all american made vehicles, as most of them are rotten.
Aug 02, 2008 | Chevrolet Tahoe Cars & Trucks
Kitchen Ranges Logo
23 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
