Question about Teac Computers & Internet
Netcom puk number - Teac Computers & Internet
Is a replacement battery available for 9120 I've used for a number of years?
GN Netcom probably would know. If you can identify the battery type, you can try obtaining a replacement from some other source.
Jul 07, 2014 | GN Netcom GN 9120 Professional Headset
How do I remove the battery out of a NetCom 2000 headset?
That is a corded headset , no battery in the headset itself. If you have an amplifier google the manual for the model of amplifier you have.
Aug 04, 2013 | GN Netcom GN 2000 Headset
I need puk code
At the time when you enter a wrong pin number three times the phone asks you for a PUK number. The PUK code is generally eight digit number. This PUK number is an unlocking code which helps you to unlock the phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to buy a new simcard. It might happen that your phone might ask you for PUK2 after you enter your PUK number. You can find the PUK code is in your SIM card documentation Starter Pack. If you do not have this then contact your phone service provider. Your cell phone service provider can give you the PUK code once they have confirmed your identity to prevent any stolen SIM access.
Feb 09, 2011 | Nokia (BL5J) 5800N900
I have a GN Netcom 8000 and I hear a beep in the headset every 12 seconds. Any ideas why?
Had the same problem with mine did not realise that there are batterys in the unit and they are going flat. Open the top and look on the right side, there are 2 aaa's inside. Replace those and you should be fine
Sep 16, 2010 | GN Netcom GN 8000 MPA Mulitpurpose...
No sink?
Yap i did solve the issue, thanks
May 27, 2009 | GN Netcom GN 9120 Professional Headset
Netcom GN9120 needs repair
I can ship you a good remanufacture unit with a new battery in the headset. Marc@universetelecom.ca
May 15, 2009 | GN Netcom GN 9120 Professional Headset
I have a Netcomm NBPlus 4 Wireless Modem/Router and I have now bought, in addition, a D-Link DVG 1402S VOiP Router. I seem to have a problem getting the two to talk to each other prior to configuring the...
Set one of them up in bridging mode.
To get to the admin screen, check the bottom of the voip box to see if it's accessed through another IP.
If you have the voip router plugged into the Netcomm router, the IP address to access the voip is going to be assigned by your netcom. Assuming the voip router isn't serving dhcp addresses (i.e. 192.168.1.100, 192.168.101 and so on)
FYI: Be sure you don't have both routers set up as dhcp servers.
You can acquire the voip router's ip from the admin interface of your netcom router.
If you are wanting to get them to talk to each other through entirely different IP addresses (subnets), create a route in your netcom router for your voip router. Bridging mode may make things easier for you.
Going back: If you have your netcom dishing out ip addresses to wireless and cable users, and you plug in the voip router to the netcom router, your voip router will receive an ip like any other computer on the network. Thus will use the netcoms ip as the default gateway and it gets messy after that --lack of connectivity.
Nov 15, 2017 | Computers & Internet
Pairing GN Netcom GN 6210 with my iphone
Press the talk button on the 6210 Device and hold it until you here (2) faint beeps. Walla! (poor design and documentation?)
Mar 08, 2008 | GN Netcom GN-6210 Consumer Headset
Computers & Internet Logo
22 people viewed this question
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
