Question about LG WM2801HRA 27" Front-Load Washer 4.5 cu. ft. Capacity, 9 Wash
Wm2801hra lg washer light stays on after wash and will not start new load
4 Suggested Answers
stradeteox
  • 88 Answers
SOURCE: LG Washer won't start
If you have eliminated the possibility of a faulty AC power cord or faulty AC outlet, then it sounds like your unit will need the main control board replaced. Probably a bad relay on the main control board.
Posted on Jan 07, 2009
rylee_smith
  • 8619 Answers
SOURCE: My LG Washer stops running
Hi
Thanks for using FixYa. LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
  • 3 Answers
SOURCE: LG WM2487H*M Drum light stays lit after each load is completed
Solution. Unplug the machine. Hold the power button for 10 seconds. Plug back in. Push the power button and the washer should turn on. Walk away leaving the machine on. When I did this, I came back to find the drum light off and machine would start on command now. Good luck.
Posted on Jan 02, 2011
My LG washer (Lg tromm Wm2377cs) is coming on by itself when the door is open. The panel stays lit, then eventually goes dead, only to come on again later by itself.
not just yet? still need to check other items? the timer, the push start? etc buying a new board may not solve ur issue less ur sure of the cause, the door actuator may be stuck closed however cant see how it would effect the start staying continually on so I would check both out at the least
Mar 08, 2013 | LG WM-2277HW Front Load Washer
Drum light stays on and unable to start our LG front loader. We successfully re-set it by unplugging it, holding the start button 10 seconds, spinning the drum 360 degrees, and re-started it and it r
I work with a parts supplier and can get you a great price. All I need is the model number that is located on the machine. It should be located inside the door frame of the washer on a plate.
Regards,
Richard Roth
FixYa Technician
Oct 14, 2012 | LG 3.6 cu. ft. Front-Load Washing Machine...
Lg washing machine drum light stays on and wont let me turn the
May 15, 2009 | LG Washing Machines
Feb 12, 2009 | LG WM2487HA Washer
Nov 30, 2008 | LG WD-1280FHD Front Load Washer
Washing machine does'nt work when switch on ,but the spinner work.i want to know what's the problem
Washing machine 7.0kg. Does not work when switched ON. The on light does not stay at Fuzzy program as it used to be but it jump straight to Delicate program.The washing machine does not move move at all even when I press the Start button.
Oct 28, 2008 | LG WFT1071TP Top Load Washer
LG WM-2277HW
It sounds like a problem with the control board.  You will need to have the unit checked out by a qualified LG technician and possibly replace the board.
Sep 20, 2008 | LG WM-2277HW Front Load Washer
LG WM2801HRA 27" Front-Load Washer 4.5 cu. ft. Capacity, 9 Wash Logo
51 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
