Question about Ryobi Tools & Hardware - Others
Ryobi ess1813 buzzing noise no start
Sheet sander worked initially for a couple minutes then stopped, now when switching on it only makes a buzzing noise. emptied the dust bag and tried clean it best i could with a can of air, house is running on a generator, but had it plugged in to a surge protector, is it broken?
flopez
  • 161 Answers
SOURCE: CyberPower 325SL won't work...
NEVER mix surge protectors and UPS!!!. Doing so overloads whoever of the two gets connected to the wall. This equipment is built to be plugged DIRECTLY to the wall. Your unit just crossed it's inner battery. Take it to a recycling center, then stop on your favorite electronis shop and buy a new one.
Posted on Sep 21, 2007
reddevil6
  • 1673 Answers
SOURCE: stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Posted on Jan 17, 2008
SOURCE: central air conditioner
thats a good one
Posted on Jun 28, 2008
  • 23 Answers
SOURCE: makita gv5000 5" disc sander won't work
there isn't an internal fuse. by the sounds of it you probably have a short, a bad brush, or some arcing.
if you use your sander for fine sanding (100+ grit paper) you have to make sure to clean out the motor housing. Fine sanding dust, like any fine dust, creates alot of heat when aerated and can melt the plastic brush holders or can cause the electricity to arc from one wire to another inside the housing.
my advice is to take the 8 (i think it's 8) screws out of the side of the gun and carefully pull the halves apart. there isnt alot you can mess up inside and just visually inspect the wires for burns or melting on the brush holder.
here's a breakdown if you need it.
http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_GV5000.pdf
if you find something inside that you're not sure of, or if you have any additional info i'll keep checking in on this.
Posted on Dec 10, 2008
  • 52 Answers
SOURCE: sander failure when using honda generator
If you are using a 220 volt 4 hp floor sander, which is 95% of all floor sanders. you CANNOT use a generator less than a 25KV, which is about the size of a van. All Floor sanders draw over 80 amps at start up and during floor sanding all sanders run around 25 amps. If your motor is a Capactor style motor you can do detrimental damage to the motor. Many of my customers have done it in the past.
Posted on Jan 11, 2009
Ryobi problems
This is not that bad of a problem we should be able to resolve this-
bring a lamp or radio which ever one you have used and know it works plug it into the wall outlet if your lamp or radio work then we know its the plug, now plug in yr Ryobi random orbital sander it should work to do not involve an extension cord while we are trouble shooting if neither have worked on the same plug you must have a 3 way light switch on the wall that needs to be turned on, try and slightly spread the the metal blades on yr Ryobi outward for a better contact between cord blades and wall plug make sure you have firmly pressed in the the on off switch.
Ryobi tests all of its factory reconditioned power tools before they are sent back to be sold in stores to the public...
Aug 10, 2014 | Ryobi Factory Reconditioned ZRRS290 2.6...
Ryobi BE318-2 dust bag don't work
The pathway that the dust follows to reach the bag is most likely clogged. Take the bag off and look inside to see if there's sawdust plugging the orifice. If there is then you could vacuum out the dust or simply start up the sander and let the machine clear itself. If you do the latter just know that you will create a cloud of dust so do it in the proper environment.
Jan 03, 2014 | Ryobi BE318-2 3 X 18 BELT SANDER
Hamilton ontario
After you factor in drive time, finding the part, waiting at the cashier and gas money I think you'll find it more cost effective to have the part delivered to your door.
http://www.ereplacementparts.com/ryobi-s652dk-sheet-double-insulated-sander-parts-c-7931_7932_8095.html
Aug 12, 2013 | Ryobi Tools & Hardware - Others
My 2nd samsung R519 laptop makes a buzzing noise and freezes wen not connected to power supply. Stops and starts every couple of minutes and lasts for a couple of seconds, very annoying!!
RAM is corrupted...i guess...
do this...
remove the power supply (both the power adaptor and battery)
keep pressing the power on button of the laptop...for some time....
install back the power and start...
let's c if this works...
Dec 21, 2009 | Computers & Internet
Ryobi half-sheet orbital started screeching - any way to lube it?
Take that sander apart and you can oil the roller externally with a good lubricant not a gel like substance but oil that is made for things to move better. Doesnt have to be heat resistant after you have oiled both sides with the belt off. Then turn it on and let it mix. You may have to do it a few times to get it to work well again
Apr 26, 2009 | Tools & Hardware - Others
Frigidaire window air conditioner making buzzing noise
i would invest in a new unit the cost to get this one repaired will add up and theres no guarantee they will fix the problem
Aug 21, 2008 | Heating & Cooling
Tools & Hardware - Others Logo
71 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Mike
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
