Question about KitchenAid Kitchen Ranges
Removing blower motor
I am trying to replace the motor on my kitchenaid kicu285hbt vents hood. I have motor out but can't figure out hoe to get the fans off the motor shafts
  • 1,384 Answers
Tap the fan on the shaft just a bit then clean the shaft with sand paper then carefully pull and rotate the fan off of the motor shaft = lock the motors rotor in a vice this make it a easy job. BUT don't damage the fan ! if it feels like it's not going to come off STOP. and search for you local electric motor repair shop with free testing. and ask him to pull it off fer ya, ask him how to oil this motor so you don't go threw this again. ?
Jay the pool pump motor repair guy in longwood Florida 32750
Posted on Feb 08, 2014
4 Suggested Answers
  • 6 Answers
SOURCE: fan blades or motor in Nucor over the stove hood
The FR Series fans from Fantech are glued closed to prevent air leakage. Its better to replace the fan than to try and fix it. The cheapest place to buy a Fantech fan is at http:///www.hvacquick.com as they buy direct from Fantech.
Alos the FR Series fan comes with a 5 Year Manufactures warranty.
Posted on Feb 10, 2009
  • 244 Answers
SOURCE: Need a motor for an old Rangemaster vent hood. where can a find?
repairclinic.com
Posted on Feb 12, 2009
BMT60
  • 126 Answers
SOURCE: I am having a similar problem...motor hums like it
YEP REPLACE THAT MOTOR. MOST OF THEM HAVE A GEAR TOOTH THAT HAS BROKEN WHICH CAUSES BINDING.
Posted on Apr 25, 2010
No air coming out of vents
On Top of your Blower Motor is a Resister that has gone bad. Most Blower Motors now have the Resister built to the Blower Motor itself but some are serviceable. Before you remove and replace the Blower, test the Power that is getting to the Motor. If the power is getting there, then you have an easy fix... The Power will be variable when you change the SPEED SELECTED (that is another test).
Mar 01, 2014 | Cars & Trucks
1996 Chevy Astro A/C heater air vents will not blow air
the blower motor is under the hood on the pass side. u have to remove the wiper and radiator bottles and also the head light. than take out the 7 bolts that hold the blower motor in than u have to remove the squirel cage before the motor will come out. or it could be the Blower Motor Resistor.
Jan 12, 2012 | Cars & Trucks
I bought new Kitchen Aid microwave with hood combination and followed the instructions to install it. Everything was OK until I came to the Wall Venting Installation, step 4. Lift blower motor out of...
On this model, item #1 is the only part you will need to invert. Lift out and rotate to allow venting to be possible to the wall. In other words, the open part needs to face the back of the microwave. Also if you removed the blower, you will need to re-install it back and correctly. You could have venting issues if not back in the proper location.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 28, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How to remove nuts that secure blower wheel to fan motor
The set screws do not have to be removed... just loosened...
Getting to them is the tricky part...
often there is a hole in the blower wheel fins so that you cn get tools into the set screws..
heatman101
Apr 27, 2011 | KitchenAid KIRD801HSS Kitchen Hood
No air blowing 1998 Ford E350
blower motor location is in the heater box down by the passengers feet the fan relay in out under the hood in the power fuse box check this first
check to see if the blower motor turns you can do this by removing the three screws the motor and squiral cage will come out spin it if it moves freely putit back replace the switch assembly
Mar 03, 2010 | 2002 Ford E350
The blower motor hums but does not move/work. When I give the motor/fan a little push with hand it starts working. A day or two later it is back to the same situation where it hums and needs a push.
The little fan is going out.you can disconnect the power to it,and remove it,to see if you can clean it,then it might start working,do not oil it,it will catch fire,but I suggest to replace it.I hope this is helpful,if so,please let us know,thank you.
Oct 25, 2009 | KitchenAid KWCU265HSS Kitchen Hood
How to replace heater core in a 1988 jeep cherokee?
Jeep Cherokee XJ Heater Core
Work for '92 models, but can use it like a reference guide.
Figure 1
  1. Disconnect battery ground cable, then drain cooling system.
  2. Disconnect hoses from heater core.
  3. If equipped with A/C, remove evaporator/blower housing as follows:
    1. Discharge A/C system, then disconnect hoses from expansion valve.
    2. Disconnect electrical connector and vent tube from blower motor.
    3. Remove console, if equipped.
    4. Remove lower instrument panel attaching screws, then the lower panel.
    5. Disconnect electrical connections from A/C relay, blower motor resistors and A/C thermostat.
    6. Disconnect vacuum hose from vacuum motor.
    7. Cut evaporator/blower housing to heater core housing retaining strap, then disconnect heater control cable.
    8. Pry retaining clip from rear of blower housing flange, then remove the three retaining screws.
    9. Working from engine compartment, remove evaporator/blower housing attaching nuts, then the evaporator drain tube, Figure 1.
    10. Remove right kick panel, then the instrument panel support bolt.
    11. Pull right side of dash outward, then rotate housing downward and towards rear of vehicle until studs clear dash panel. Remove housing from vehicle.
  4. Remove heater core to housing retaining screws, then the heater core, Figure 2.
  5. Reverse procedure to install.
Figure 2
Personally, I'd pressure test the cooling system then look at the heater core to see if it leaks. It may just be a loose clamp or leaky hose.
Also can check the forum jpmagazine.com
I hope help you; good luck (remember rated this).
Sep 15, 2009 | Jeep Cherokee Cars & Trucks
Air and heat not blowing air through vents
Either Your fan switch is burned out or you blower motor is no good, your blower motor is on the passenger side under the dash. Before you replace any parts you need to check your fuses and relays under your hood and in the car. Usually if your fan switch goes bad you will still get some air blowing thru the vents, so my guess would be blower motor, If its not a blown fuse or relay.
May 28, 2009 | 1999 Cadillac DeVille
Kitchenaid downdraft retractable vent
Your drive motor arm is not making contact with either of the two limit switches at 6 and 12 positions. Your arm may be loose, gear stripped, broken bracket. Turn off the power at the breaker panel and remove the vent pipe cover box (4 nuts) see what is going on inside. Tellstar
Mar 01, 2008 | KitchenAid KHTU165RSS Stainless Steel...
Kitchen Ranges Logo
378 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
