Question about Philips FW-R7 CD Shelf System
Switch aux without remote
I tried plugging my phone into the aux/headphone port and i can't hear anything. I hit the aux button on the stereo but it's not doing anything
Is there a way to play my IPhone music on Hyundai Accent 2005 Stereo? It's annoying that I have to use a CD.
Play music through USB in the car - Windows Central Forums
forums.windowscentral.com/.../209188-play-music-through-usb-car.htm...
Dec 19, 2012 - 25 posts - ‎18 authors I own a Hyundai Sonata 2012 which has a USB port that worked perfectly for listening to music on my iPhone. ... and it SUCKS. i want to be able to charge my phone via USB while I listen to music. .... I even bought an ALPINE stereo head unit and tried that, as they supposedly work with NOKIA phones, but.
Oct 21, 2015 | Hyundai Cars & Trucks
The aux entrance, which i use for listening to my headphones is stuck, can i fix it?
Just pull it out. All it is; is a pin that slips into the port. If too tight, try some 10D contract spray on the AUX port. It wont hurt the electronics as it is made for electrical contact use.
Jan 21, 2015 | Toshiba Satellite Computers & Internet
My ooutdoor tecnology tags are not charging on my mac when I plug in I keep swicthing plug in port . Any Ideas??
How old are they and have you left them on the charger for long periods of time? The batteries are small and dont last long if they are old or constantly over charged.
Sep 09, 2013 | Outdoor Technology Ot Bluetooth Tags...
XO Vision XD 103 USB Troubleshooting
the answer is the AUX port. get a cord that plugs into your iphone's headphone jack and has the same plug on the other end to plug into the XO Vision's AUX port.
Jul 20, 2013 | XO Vision XD103 FM and MP3 Stereo Receiver...
How can I hook my Sandisk Sansa Clip+ up to my stereo system if the stereo doesn't have a USB port?
Connect a audio from the headphone socket on the player and plug it into the AUX input on the stereo system. Set the stereo to AUX, turn on the player and adjust the volume level on the stereo.
Nov 28, 2012 | SanDisk Sansa Clip MP3 Player
I can not hear anything and the phone has the headset icon on, how do i get it off
There is a switch inside your headphone jack. When you plug your headphone in it moves and breaks connection telling the phone that the headphones are plugged in. Try plugging and unplugging a headset to see if it frees this switch up. If not you may have a malfunctioning switch.
Also, turn off bluetooth if it is on...it might be hooked up to a bluetooth headset if you have one.
Jul 24, 2011 | HTC Cell Phones
I had my phone plugged into an aux port in my car to listen to music. when i took the wire out and went in my house I recieved i phone call and could not hear anything when i answered. so I called a couple...
ok this can be a common issue, it would help to know the make of the phone but here a few things to do/check
1st check the aux port to make sure nothing is damaged
if all looks fine then its most likely a software glitch and the phone is stuck in headphone/handsfree mode
in most cases simply restarting the phone will suffice, however if this does not resolve try the recomended manufacturers reset code/option to fix
(warning this may result in loss of data, so backup anything important!)
Mar 06, 2011 | Cell Phones
How do you hook up your ipod through the rca cable hookups in the back without the radio still playing?
This is different on every stereo, but generally the RCA ports in the back of the stereo are labeled "Aux" or something to that extent.
First, you must purchase a headphone jack to RCA cable which can connect to both your stereo and your ipod.
Connect the cable, turn your ipod on and start playing a song. Turn the volume on the stereo to a moderate volume so you can hear when the song is being played through your stereo. Then, using the selector switch, turn the stereo from "Radio" to "Aux" or whatever it says next to the the RCA plug ins on the back.
Aug 14, 2009 | Pioneer DEH-2000 CD Changer
I have F&D home theatre i want to connect it to laptop
go to radio shack or walmart . get a cable that has an 1/8th inch stereo plug on one end and two (male) rca plugs on the other end.
make sure your volume is not all the way up on either the computer or the stereo.
plug the 1/8 inch plug into your "speaker or headphone" jack on the laptop.
plug the red and white (male) rca plugs into the auxilary or cd "IN" on the home theatre.
Power up the stereo, make your source on the home theatre the Auxilary or CD, whichever you used to plug the RCA's into.
now you should hear anything from the laptop through the home theatre.
Regards..
Apr 25, 2009 | Creative Labs Sound Blaster Live! 5.1...
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Philips FW-R7 CD Shelf System Logo
32 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
