AMPLIFIER CUTTING OUT - Audio Players & Recorders
    New Friend:
  • 87 Answers
You have a capacitor problem. Check and replace.
Posted on Feb 08, 2014
My harman kardon avr 100 keeps cutting out every 3 secs. i can hear the music but constently keeps cutting off. its very annoying... any ways to fix this probem?
Check the impedance of the speaker wires going into the amplifier. It sounds like at least one set of speakers is overloading the amp (shorted, or almost shorted)
Jul 24, 2011 | Harman Kardon AVR 100
ED7400 - Edge Car Audio 400w amplifier keeps cutting out the music and going into protective mode.
The most common problem is that the amplifier isn't getting enough power. Try installing a one farad capacitor between the head unit and the amplifier.
Oct 04, 2010 | Car Audio & Video
I have a mtx thunder amp. It started cutting in and out, when it did that it would make a loud sharp noise thru the subwoofer and then work fine. after turning my truck off and cutting it back on it would...
WELL, THE BAD NEWS IS THAT IT WILL DEFINITELY NEED TO BE SERVICED, BUT WHEN REINSTALLING IT, MAKE SURE TO HAVE THE SPEAKER CHECKED TO INSURE THAT IT IS NOT FAULT Y, AS IT COULD HAVE A BAD VOICECOIL WHICH CAN PRESENT A SHORT TO THE OUTPUTS OF THE AMPLIFIER RESULTING IN PREMATURE FAILURE. IF IT IS FINE, THEN REINSTALL THE AMPLIFIER AND YOU SHOULD BE OK FROM THERE. ALWAYS KEEP IN MIND THAT ALL POWER CONNECTIONS, ESPECIALLY THE GROUND, SHOULD ALWAYS BE CHECKED TO MAKE SURE THEY ARE 100%. HOPE THIS HELPS AND LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Nov 24, 2009 | MTX Thunder 251D Car Audio Amplifier
Lights on crosover not light up and sub is cutting in and out
Hi mate i had a similar problem and it was a dry joint in the equaliser. Maybe an Easy fix.
Then again iv seen bad wiring cause the same problem. If the subs are cutting off, are you using the correct cables and are you sure the amps not cutting off?
Oct 24, 2009 | Crown STEREO CROSSOVER NETWORK, MONO...
System cutting out, then cuts back in
Cheak your earth cable and positive at all joins and fuse spots earth should be nice and tight good luck
Oct 18, 2009 | Ranger MARTIN PS-55 KARAOKE MIXER...
My amp keep on cutting off
wha amp do you have? and when it cuts off? did ou try to find a different ground make sure it is a good ground anx make sure your widt of the mains can handle the amperage of the amplifier
Apr 04, 2009 | Orion 1200D Car Audio Amplifier
6000d amplifier cutting off
Hi...
Crown has posted on their website all the tech info you can probably use for your situation.
Cheers!
Jan 15, 2009 | Crown XTi 2000 2-Channel Amplifier
Sound cutting out
Was the amplifier installed by a professional or shadetree installer?
May have tapped into wrong wire for amplifier turn-on.
Jan 02, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Crate BT50 Bass amp cutting out with high input.
Sometimes an amplifier's preamp can't handle certain signals/frequencies at a high gain, so they cut out. Bass guitars are especially prone to giving such a strong signal.
I bought an older, nonworking bass amp recently and fixed it just to find it had the same problem. Best solution is to put a low ohm resistor at the amps input, but if you turn your guitar down to half volume it'll have the same effect: should prevent it from cutting out.
Nov 01, 2007 | Crate SPA1600 Power Amplifier - SPA Series...
Amplifier cutting out when volume is increased
yea my friend your audio ic or transistor is either getting faulty or you have lose connection have a tech look at your set and make the nessecary repairs.good luck
Apr 26, 2007 | NAD C340 Integrated Amplifier
26 people viewed this question
 Grubhead
Grubhead
