I have a psych class that requires me to use an access code to complete my work assignments, but the access code is nt working. I am behind in my class as a result.
If a professor gives you one week to write a fully referenced 20 page paper, is he setting you up to fail?
writing a reference paper requires some skills and abilities.
for some students, a week is not sufficient and for others, 4 days are enough to complete the academic writing task.
do nt worry
if you need assistance in the writing tasks, contact via the included link..
Assignment Help 4 Me Get Rapid Homework Help from Professional Tutors
Jan 04, 2017 | Higher Education (University)
I have a 03 Saturn Vue that has electrical issues sometimes it dose not start and I have to remove the ignition and main battery fuses to get it to start. Up cluster works when wants along with dash lights...
Sounds like you mite need an ignition switch. But just to be sure you should have the modules scanned for codes , especially the body control module ! Are any warning lights staying on ,check ENG , A symbol of a wrench lit up or a picture of a lock symbol ? This car has a few electronic control modules and there all talk back an forth on a serial data bus . This car has two !
Class 2 Data Line
Saturn utilizes the class 2 communications system for most vehicle system controllers that must exchange data and commands. Class 2 data is pulse width modulated. The pulse width modulation of class 2 data allows better utilization of the data line.
The messages carried on class 2 data streams are also prioritized. This means if 2 devices try to communicate on the data line at the same time, only the higher priority message will continue. The device with the lower priority message must wait. The modules on the class 2 data line are:
Body Control Module (BCM)
Power Steering Control Module (PSCM)
Instrument Panel Cluster (IPC)
Inflatable Restraint Sensing and Diagnostic Module (SDM)
Vehicle Communication Interface Module (VCIM), if equipped Controller Area Network (CAN)
The controller area network (CAN) serial data line is a high speed serial data bus used to communicate traction information between the electronic brake control module (EBCM), the engine control module (ECM), the body control module (BCM), and the transaxle control module (TCM). Typical data-transmission speeds must be high enough to ensure that the required real-time response is maintained.
The addressing scheme employed with CAN assigns a label to every message, with each message receiving a unique identifier. The identifier classifies the content of the message, such as engine speed.
Each module processes only those messages whose identifiers are stored in the module's acceptance list. This is CAN's form of message filtering.
The identifier labels both the data content and the priority of the message being sent. Each module can begin transmitting its most important data as soon as the bus is unoccupied. When more than one module starts to transmit simultaneously, the message with the highest priority is assigned first access. A module responds to failure to gain access by automatically switching to receive mode. The module then repeats the transmission attempt as soon as the bus is free again.
You need to have a professional scan tool to check for codes in the modules other than the engine ecm module. I have seen a bad instrument cluster short the bus and cause the vehicle shut down . hope this helps ! First place to start is checking for codes in all the modules. If there is a problem with one of them ,it usually sets a code in one of the other modules !
Jan 07, 2015 | 2003 Saturn VUE
How do I rewrite this sentence? Many students who take online classes do not realize that the time commitment for online classes is often more demanding than that for face-to-face classes, which ofte
"Student time required to complete online lessons is often more than the time required for face-to-face classes. Many online students do not realize this, causing them to fall behind.
Oct 08, 2014 | Computers & Internet
Aplia access code
You have this posted in the wrong category.
Jun 11, 2012 | Cars & Trucks
I am enrolled in It214 and IT355. Kaplan assigned me a web server that I am unable to access through IE or Foxfire. I have entered http://ist2w.kaplan.edu/htcomnet and http://ist2w.kaplan.edu/support....
If you are getting a message about not having a default page setup after uploading your files, make sure that you have uploaded your files to your class directory in your folder. For example, if you are in IT117-05, make sure you are in your IT117-05 folder before uploading your files. To do this in the web interface, double click your class folder in the right pane to enter the folder. Once you are in the folder, upload your files. Also, DO NOT DELETE your class folder. If you are using Dreamweaver and getting this error, make sure that you have your remote folder set to your class folder name.
Jun 14, 2011 | Computers & Internet
Hi, I have a panasonic kx-t7633. we can dial all the numbers but not those starting by 76 which is the code for mobile phones. How can I assign the line 4 to dial these numbers?.
It's not magic. You need to program several things that require installer access. In your features manual, look up COS and TRS (Class of Service and Toll Restriction). It's probably already in your system and you need to modify the programming to make it work. Another feature called ARS would possibly be in order, then, you dial 9 and the number and the programming would sort it out.
Needless to say, it's beyond the scope of a free forum to do specific programming on your system.
Carl
May 19, 2011 | Panasonic KX-T7633 Corded Phone
Hi,I will like to have ? list of various websites that can Actually help with Answers to assignment
Website perform several functions. For example, website provide recognition of business establishments where amongs several data that is provided on site are resources contributing towards establishment operations. Websites may provide resources referencing where for example microsoft device sites provide technical support requirements. Alternatively, websites may have live features where for example, exchange of resources are achievable. Several websites perform various functionalities amongs which assignement resources are contributed towards. For example, school website provide shared resources also possible are assignement resources exploration features. However, websites could be designed to suit specifications explained briefly. If i was asked to design a website to help answer assignments, the following requirement would achieve the process.
First, The course subject would be required to determine assistance type. For example, math classes require calculator websites either as resource formular pages or formular establisment sites. if i was required to design a math class website, the formale sheet would be required to be key coded. Asking a computer programmer to create a web site would require the following lists.
1. The type of website, an example of which is assignment answering resources center.
2. Second, the programmer requires examples of what the website would perform to the requestor. For example, a simple assigments website in maths would have a separate page for calculator functionalities. Alternatively, maths websites may require from the requestor the trype of questions of assigments as module of construction. For example, i want a webpage to calculate by adding numbers. Programmers should be provided with 1+1 =2 where 1+2=3 as programmers visual guide to designing and coding the website. keep in mind that the type of request from the programmer would determine what would be produced.
Jan 11, 2011 | Computers & Internet
Will maxtor 3200 work with windows NT and if so where do you find drivers
Here are the requirements according to Maxtor: Hardware and Operating System Requirements for Windows PC ? Pentium III-class equivalent processor or later ? Windows 2000 or XP ? 128MB RAM or more as required by operating system NOTE: Macintosh Systems are NOT supported with this product. Here is a link to the User Guide: http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/ps3200_users_guide.pdf
Dec 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Off site access to view security camara dvr
access the router look for portforwarding and enable port forwarding assign a name to your camera
type in the port your camera use. ex 593
then type the assign IP for your camera ex 192.168.1.6
to access it type in your browser the your public IP ex. 209.45.0.0:593
read your ip cam manual for accesing it.
Nov 12, 2008 | Computers & Internet
Static IP on machine, now can't access web sites
Please see the related article on assigning a static IP address behind the router. If you still can not access websites, please try changing the static IP address you're using. For example if you're using the address 192.168.1.2, try 192.168.1.200. If that does not work please try the same static IP address on a different computer to see if it can use the information. If it can please try reinstalling your network card. If that doesn't work please contact Linksys Technical Support.
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
