Question about Jandy Pool & Spa
3 hp relay burnt wires
I have a Jandy Aqualink RS system that was working fine until today. Our filter pump and heater stopped working so I opened the control box to find the cables wired to the line 1 and load 1 terminals of the 3hp relay were fried. I don't know what caused this and I don't want to replace them only to have it happen again. Any thoughts?
  • Jandy Master
  • 17,328 Answers
Those wires connect to the pump. It is overloading the system. The heater is protected by breakers so that should not be the issue. That is if the system was wired as recommended. Replace the pump if you inspect the wires and find that they are not contacting each other or ground anywhere. If they are damaged, you will have to replace the wires.
Posted on Feb 08, 2014
4 Suggested Answers
  • 128 Answers
SOURCE: Jandy Aqualink RS
Disconnect the spa side remote.
Posted on Aug 23, 2009
SHANEOK
  • 21 Answers
SOURCE: Jandy Aqualink with IntelliFlo VS-3050
Jandy has an e pump.It would be cheaper to go that route.the Inteliflo is not compatible with the jandy system .If money is not a concern the pentair product is the way to go.
Posted on Oct 04, 2009
  • 246 Answers
SOURCE: Jandy aqualink RS handheld went out during
GO TO THE MAIN PANEL AND RESET THE SYSTEM
Posted on Oct 13, 2009
How do I fix an Jandy ePump?
open up the power box see if still wet dry out make sure communication plug is dry then power everything down reboot and try again if it doesnt work the main board in the pump is no good
May 25, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Power to control panel is off and pump continues to run ?
you need a new 3 hp relay trace wires from filter button red and black wire go to the relay
Apr 12, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
My Jandy rs all button says the pump is off but the pump stays on. This has happened before and it seems to reset its self or after i turn the pump breaker off it resets. What is going on?
Very odd.
I would suspect a bad relay.
Go to the outside power center located at the equipment. Press the mode button until the "Service" light is on. Now press the filter pump button. Turn it off and on several times to make sure the relay is working correctly. If not, replace the relay.
If this is not the problem then I would reset the board at the power center by pressing the recessed "Reset" button with the tip of a pencil or pen.
If this does not work, you could call Jandy and have them flash your board with the newest software.
Apr 16, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy filter and pump with a aqualink. Pump
Once you turn it off their will be a heater override that will keep the pump running for five minutes so the heater can cool down. Be sure that you give it that time.
Feb 09, 2010 | Jandy AQUALINK RS TELELINK KIT
Sep 29, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
AQULINK CONTROLLER WILL NOT TURN OFF FILTER PUMP
Sounds like one of the relay's has gone bad inside the box. If your lucky you can move the wires to another relay if there is one available. Make sure you move the top wires too, not just the 4 bottom wires, or you will have to do some reprogramming.
Mar 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
62 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
