Need my password,username - Computers & Internet
Have a new netgear72 router how do i find password
For most NETGEAR devices (except ReadyNAS/ReadyDATA products and Fully Managed Switches), the default username and password is:
  • Username (all models) = admin
  • Password (current models) = password
  • Password (very old models) = 1234
Default username and password for ReadyNAS/ReadyDATA products:
  • Password (ReadyNAS OS and ReadyDATA OS) = password
  • Password (RAIDiator firmware) = netgear1
  • Password (Infrant firmware) = infrant1
Default username and password for NETGEAR fully managed switches:
  • Username = admin
  • Password is blank (no need to enter any password).
May 02, 2016 | Computers & Internet
Wanted to set password om my linksys
Reset your router back to it's factory settings by holding the reset button for about 5 seconds.
I have provided a list of the most popular router brands. If it does not work you may need to
google what your specific model's default IP address/default username/default passwords are, for
example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it
can depend on where you obtained your router. If you purchased it yourself from a store then the
standard defaults should work. If you obtained your router from your Internet Provider you may
need to contact your service provider. It also may depend whether it's an old or new model router
as well. And you may need to press and hold the reset button on your router several times before
it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is:
192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or
192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Computers & Internet
Forgot my password and cannot reset?
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
Sep 06, 2011 | Computers & Internet
Username and password eset nod32
Use these :
Username:EAV-49155849
Password:nscherb3kh
Username:EAV-49153926
Password:p6av4m3ned
Username:EAV-49155265
Password:2m6aus3634
Username:EAV-49155912
Password:5stk6hr2xk
Username:EAV-49155915
Password:h5tct7cd3a
Username:EAV-49155269
Password:vnkfn7b8hr
Aug 16, 2010 | RTO Eset NOD 32 Antivirus System 3.0 Full...
Username and password for eset full version
TRY ONE OF THIS AND DON'T FORGET TO RATE
Username: EAV-30046840
Password: 43xm3j2aen
Expiry Date: 25.07.2010
Username: EAV-30047000
Password: mj4nmbudvk
Username: EAV-30518969
Password: m6ksru4vm6
Expiry Date: 28.07.2010
Username: EAV-30191114
Password: a5utejpdvm
Expiry Date: 29.07.2010
Username: EAV-30662248
Password: tc45mbsaex
Expiry Date: 02.08.2010
Username: EAV-30490460
Password: pv3hcjvc44
Expiry Date: 06.08.2010
Username: EAV-31499771
Password: v3te8xpasu
Expiry Date: 05.09.2010
Username: EAV-31499778
Password: u84apanjkt
Username: EAV-31502567
Password: ueee6cuctx
Username: EAV-31550064
Password: rd7fcrks3u
Expiry Date: 08.09.2010
Username: EAV-21460280
Password: k4tjae4maf
Expiry Date: 12.09.2010
Jul 04, 2010 | RTO Eset NOD 32 Antivirus System 3.0 Full...
Need username and password
there are few username and password which your router accepts
try these
Username - user
Password - user
Username - admin
Password - admin
Username - admin
Password - cciadmin
Jul 01, 2010 | Paradyne (6211-A2-200) Router
When i click on my Hard drive D the icon said: the disk in drive D is not formated do you like to format it? Off course i don't like to format it,is full of important files. It must be a virus ... Pls...
Open Winrar
in the address bar type the D:
all the file like
ravmon.exe
folder.exe
autorun.inf
found.000
smss.exe
etc
delete those by pressing shift + delete key
If it give you error then Reinstall the windows again and delete the previous one from c:
then do the following things that I said
And remember as you double click the d:\ the virus gets activated and your PC will become slower day by day
Use NOD 32 2.7 old version which is better then the latest version then update is
10 September 2009 username and password of nod32
Username:EAV-20830846
Password:p45sbe3ax3
Username:EAV-21097603
Password:bc7j4n2rj5
Username:EAV-20541617
Password:6srdsue8d8
Username:EAV-20544234
Password:pxtdf8m4th
Username:EAV-21228225
Password:dfdvte246a
Username:TRIAL-21227315
Password:ct63tfvfjx
Username:TRIAL-21227321
Password:fjk6fpja3h
Username:EAV-20831172
Password:aea6jnxu8j
Username:EAV-20806371
Password:53epdv4mtx
Username:EAV-21247677
Password:hrvfkxk3sd
eset nod32 keys and eset nod32 username and password NOD32 ID september 9, 2009
Password:hrvfkxk3sd
Password:p45sbe3ax3
UserName:EAV-21097603
Password:bc7j4n2rj5
UserName:EAV-20977108
Password:uetk8tmx7e
Password:6srdsue8d8
Password:pxtdf8m4th
Password:dfdvte246a
Username:TRIAL-20993870
Password:chbps48hn2
Username:TRIAL-20993869
Password:2b5hta8bxj
Username:TRIAL-20993866
Password:efuf3nvd7a
but one Important thing Please Vote me first
Sep 24, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hi need to log in my rourter
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser.
By default the ip address should be set to 192.168.1.254
type .........http://192.168.1.254
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are blank.
Click the Ok button to log in to your router.
If you already had a password, you need that or need to reset the router to factory settings in order to start over again.
Oct 29, 2008 | Blitzz Technology (BWA611) Router
Needs password
Use default username and password, should be found under the router.
Try:
Username: admin
Password: admin
Username: admin
Password: password
Username: admin
Password: sky
Username: admin
Password: (blank no password)
Jun 20, 2008 | D-Link Wireless
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
